Are you fed up of using Fig. 8 section and Keder strip to reduce your 6mm bead to 4mm to slide into your Fiamma awning then read on.
Just bought a new Kampa Rally awning but one with poles and it only comes with the 6mm bead, the Rally motor ones come with 6mm and 4mm but only in Air form which is too expensive.
Normally you would use the Fig 8 section and twin Keder strip which is a pain so I pulled out the 6mm bead insert from the new awning and pushed in a 4mm one that I had pulled out of an old awning.
Not too difficult to pull out the 6mm but all but a foot of the 4mm went in so I just cut that bit off and popped it into the other end.
