Using "City" water in the winter.
Discussion in 'American RV's' started by American Dream, Aug 26, 2008.
  1. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Just a thought.
    We have a "super" pitch booked over the Christmas period and I am concerned about the supply freezing up in the pipe from the supply to the RV.
    Is it necessary to lag the pipe please in the eventuality there may be a sharp frost or snow.:Cool:
  2. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    I assume that your going to hook up to the city water supply on you rv. Its a difficult one to answer really.
    Just looking at the obvious ones, how cold is it going to get, willl the water in your supply line be running or static, if its night time which is probabley when its the coldest it will probabley be static.
    Better safer than sorry, insulate it.
    Sorry I cant think of a better answer.
    Jim
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Thanks Jim.
    Yes it's the night time I'm worried about, when the water is static.
    I was thinking of lagging the pipe with the stuff you can buy in B & Q and using nylon ties to hold it on.
    Looking at recent Christmas' it'll probably be mild but I don't really want to risk it.
  4. Jim
    Jim Ringleader
    Jul 19, 2007
    26,435
    78,084
    Sutton on Sea
    It won't matter Steve, if its going to freeze then disconnect and use your potable. If the last dozen Christmases in Wales are anything to go by, it won't be frozen water that will be the problem. :BigGrin:
  5. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    But what about all those lovely HOT baths the girlies are planning?:cry::Rofl1:
  6. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: We have NO such problems on Camping Almafra. :Rofl1::Rofl1::Rofl1:
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,360
    5,378
    East Sussex 01-580-881288
    The mind boggles!:Blush:
  8. des
    des Read Only Funster
    Oct 1, 2007
    128
    south staffs
    steve
    if it freezes up, just switch on your pump and draw from the tank.
    des
  9. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,671
    Ecclefechan
    The strangest system I ever saw was at Roseberry camp site in Willingham near Cambridge.
    I was a complete system with a tank by the caraven and a hose going to the nearest tap. The whole lot was lagged with the foam tubes that can be bought at DIY stores. The tank was wrapped in plastic which I take it had insulation under it. :Eeek:
    Clearly this occupant had the same concernes about freezing, & it was snowing & very cold so he was right to protect his water system. :thumb:
  10. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Will do Des.
    That'll keep their water usage under control.:Rofl1:
  11. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,481
    2,594
    UK / Spain
    Hi we dont have the problem with our water tank, it's the waste tank and waste pipes we have the problem with all being outside. So we used pipe lagging on the pipes and leave the drain cap of the tank and put a big container under it to catch the waste and keep emptying it. Its easy better than the waste tank freezing and not being able to empty it. It's all good fun, one of the joys of traveling down to Spain in winter, is getting through France which was hell in January.:Rofl1: I would say its better to be safe than sorry and take a Hair Drier with you they come in handy sometimes.:thumb: Good Luck. Bob.
  12. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    I would just top the tank up to albeit the tap more likely to be frozen as well so the tanks the answer:Wink:
  13. PeteH
    PeteH Funster
    Nov 22, 2007
    2,132
    2,664
    East Yorkshire
    winter water-land!!
    Lived both winters 1998/9 in R-V whilst building, did`nt bother with "City" feed just topped up the tank as needed and blew the hose dry until it was needed again. Biggest problem is "Black" tank (if it`s exposed,) frozen poo is hard to move!!. the grey tends to get regular doses of Hot/Warm washup/shower water and can be dumped then. If your valves are outside and exposed hot (not boiling) water should shift them if they freeze stuck. Mr Sheen helps too! squirt some up the pipe onto the valve faces and spindles.
    pete
  14. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    Hi Steve don't forget to put a pressure regulator in the water feed to your city water point! Or it is possible to cause some damage with out one:Sad::Sad:
    Regards Pat
  15. Tony Hunt
    Tony Hunt Read Only Funster
    Sep 27, 2007
    219
    Wimborne, Dorset
    If you all get regular and que up and Poo together then tip it you wont have a problem, can always add a kettle of hot water to it to make it flow better :Rofl1::Rofl1::Rofl1:
  16. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  17. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Cheers Pat.:thumb:
    I've seen these advertised.Will sort one.Do you need special connectors for the Bus and Tap side and special high pressure hose?
  18. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Oooooh Yuk!
    Tend to make them stick to the rule....No solids down the loo....and it's worked so far.:Rofl1:
  19. bobandjanie
    Apr 28, 2008
    4,481
    2,594
    UK / Spain
    Hi Steve thanks for that tip, I have a can of spray foam in the garage somewhere I will have to do ours, I think as long as it just goes on the tank it will be OK, but I worry that it holds the water and rots the floor. May have to mask it up and just spray the tank. Thanks Bob.:thumb:
    Thats the foam insulation holding the water not the tank.:Rofl1:
  20. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    I'm going to spray a small area at the very top of the tank first, just to make sure it goes on ok and does not react with the tank material.:thumb:
    Going to check out the water retention properties of the foam first.From what I have seen before it has very small isolated bubbles and rejects water ingress.Will test at the weekend.
    If need be I would spray/coat the floor first with waterproofer or some sort of underseal for just that reason.:thumb:
