- Aug 20, 2007
- 574
- 637
- Frankia I7300 BD
- since 1997 (many years tugger before then)
Here's my experience of using autogas in very cold weather :
I've got a 40 litre bulk tank and at the end of January, over a mild couple of days, I 'burnt' off the entire contents of the tank. I then filled up with autogas at Morrisons, got just over 32 litres in, which is approx 80 %, so the pressure limiting valve must be ok.
I was in Braemer recently when overnight the temp dropped to about -12 C. At 8 am the temp was -10 C and the gas would not light in the van. I carry a spare 6 kg Calor propane bottle in the old gas locker which I then switched over to (simple diverter switch in the locker) and the gas was flowing into the van.
The calor bottle is effectively inside the insulated van, but this shouldn't make any difference (should it ?).
It took the sunshine on the side of the van (were the bulk tank is) to make the autogas work, this was at 10 am, and the temp was then -5 C in the shade & possibly warmer in direct sunshine.
Are we being sold autogas with a fair bit of butane in it or what ?
Maybe there is moisture in the externally mounted bulk tank / pipe / regulator that freezes.
How do others get on with autogas in bulk tanks in very cold climates ?
I'd hate to think I was in the alps for any duration without hook-up relying on autogas !
I posted a similar report a couple of years ago on the motorhome list site, and one reply mentioned similar problems and cured by insulating the gas feed pipes from the tank into the van, but I'd forgotten about it until it recurred last week.
Good job we were on hook up and warm as toast in the van.
Any ideas why the above has happened ?
regards
Allen
ps submitted this to the motorhometoday site but no response as yet, so come on !
regards
Allen
