USB Connectors (1 Viewer)
ShiftZZ
21,383
84,550
Dark Side of the Moon
Doew anyone know where I can buy a USB multi-connection kit...
I have a number of different devices, iphone, cameras etc and they all have different connectors.. Is there a multi-USB kit?
ShiftZZ
ShiftZZ
21,383
84,550
Ken
The issue is whats at the end of the USB cable..
Cameras.
Canon EOS400D
Fuji Finepix
Samsung FinePix
Sony Cybershot
They all have different terminals...
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Ken
Cameras.
Canon EOS400D
Fuji Finepix
Samsung FinePix
Sony Cybershot
Thats so that they can sell you one of their in house adapters, at their price of course!
Doug.
PS its called "RIP OFF"
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
Ken
Cameras.
Canon EOS400D
Fuji Finepix
Samsung FinePix
Sony Cybershot
Im reasonably sure that at least three of those have the same connection at the 'object' end and a usb at the other...
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
OK Hilda, now I have my netbook up I can answer you properly.
What you want is called a USB hub.
In my experience the ones branded "Belkin" are the best.
The hub plugs into your pooter USB port.
The other end will have anything between 3 and 6 connectors.
The pooter end of your leads is always the same this is the end that plugs into the hub.
Some items will not work on a hub though this is rare these days. In the past printers and scanners can be iffy on a hub but in recent years all mine work ok.
Price depends on quality, a cheap one will cost around £4. I would pay the extra for a Belkin one.
Hope this is clearer for you. ::bigsmile:
ShiftZZ
ShiftZZ
21,383
84,550
No its not a hub
Each device has at one end a USB terminal and on the other a different type of terminal. Looks like they are made for each device.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
No its not a hub
Sorry Hilda it IS a hub.
The odd end of your lead plugs into your device. e.g. a camera.
The other end is common otherwise you would not be able to plug it into your computer.
This is the end that plugs into the hub. :thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Looks like what you are after is what you have already got, but shorter.
No, I've never come across a multiple USB data connector set.
It's a real pain I agree. A stupid real pain the the neat mini-USB connector is small enough for any device. Kindle are just perverse altering it by a tiny fraction.
And while we are on a good RANT, chargers, why have I 20 wall warts here and all different !!!!!
ShiftZZ
ShiftZZ
21,383
84,550
I may not be making myslef very clear...
"odd end of your lead plugs into your device", yes that the issue, I want a kit atht allows me to connect whatever with one cable (interchangable ends)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Then the answer is No there is no such thing. :cry:
I thought you meant you did not enough ports on your pooter. :Blush:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Then post number 6 does it for you hilda, one USB one end and mutiple ends the other a wide choice to cover most of what you need, a usefull kit, one ordered.
Link Removed
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
I have never seen one of those before:Blush:
I would be concerned though if you attached multiple devices would they all work correctly bearing in mind as i said some devices do not even like hubs? :Doh:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Link Removed
Only for charging !
Jan 24, 2010
2,440
4,848
Adria Twin
if only for charging, then the multi end does it
If for data connection then the USB hub is the only real option
Perfect solution doesn't exist yet that im aware of, but i would love to be corrected on that
Even the so called standards arent always the same, mini USB as an example, some manufacturers change around the data pins so they dont work with others using the same type of port...gits!:Angry:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Know exactly what you mean, I carry a bag of leads around for this purpose. I did get some adaptors from Lidl a while back, in a kit with a mini mouse and a numeric keypad etc, about a tenner. I also got some adaptors, designed for phone charging from Poundland. They are fully wired so can be used for data transfer as well as charging. The Kindle one is a real weirdo and I haven't found an adaptor for that yet.:Sad:
