USB Connectors
Discussion in 'Computers' started by ShiftZZ, Aug 26, 2011.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Doew anyone know where I can buy a USB multi-connection kit...
    I have a number of different devices, iphone, cameras etc and they all have different connectors.. Is there a multi-USB kit?
  2. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,579
    11,816
    Champagnac-La-Riviere
    any PC shop Hilda even Tesco
  3. ShiftZZ
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Ken
    The issue is whats at the end of the USB cable..
    Cameras.
    Canon EOS400D
    Fuji Finepix
    Samsung FinePix
    Sony Cybershot
    They all have different terminals...
  4. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Thats so that they can sell you one of their in house adapters, at their price of course!
    Doug.
    PS its called "RIP OFF"
    • Like Like x 1
  5. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Im reasonably sure that at least three of those have the same connection at the 'object' end and a usb at the other...
    • Like Like x 1
  6. davvidof
    davvidof Read Only Funster
    May 24, 2010
    52
    Felixstowe
    • Like Like x 1
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
  8. Munchie
    Jul 28, 2007
    8,579
    11,816
    OK Hilda, now I have my netbook up I can answer you properly.
    What you want is called a USB hub.
    In my experience the ones branded "Belkin" are the best.
    The hub plugs into your pooter USB port.
    The other end will have anything between 3 and 6 connectors.
    The pooter end of your leads is always the same this is the end that plugs into the hub.
    Some items will not work on a hub though this is rare these days. In the past printers and scanners can be iffy on a hub but in recent years all mine work ok.
    Price depends on quality, a cheap one will cost around £4. I would pay the extra for a Belkin one.
    Hope this is clearer for you. :BigGrin:
  9. ShiftZZ
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    No its not a hub
    Each device has at one end a USB terminal and on the other a different type of terminal. Looks like they are made for each device.
  10. hilldweller
    Dec 5, 2008
    27,314
    26,305
    Macclesfield
    Do you mean a HUB ?
    Or a few leads ?
  11. Munchie
    Jul 28, 2007
    8,579
    11,816
    Sorry Hilda it IS a hub.
    The odd end of your lead plugs into your device. e.g. a camera.
    The other end is common otherwise you would not be able to plug it into your computer.
    This is the end that plugs into the hub. :thumb:
  12. hilldweller
    Dec 5, 2008
    27,314
    26,305
    Macclesfield
    Looks like what you are after is what you have already got, but shorter.
    No, I've never come across a multiple USB data connector set.
    It's a real pain I agree. A stupid real pain the the neat mini-USB connector is small enough for any device. Kindle are just perverse altering it by a tiny fraction.
    And while we are on a good RANT, chargers, why have I 20 wall warts here and all different !!!!!
  13. ShiftZZ
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    I may not be making myslef very clear...
    "odd end of your lead plugs into your device", yes that the issue, I want a kit atht allows me to connect whatever with one cable (interchangable ends)
  14. Munchie
    Jul 28, 2007
    8,579
    11,816
    Then the answer is No there is no such thing. :cry:
    I thought you meant you did not enough ports on your pooter. :Blush:
  15. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,958
  16. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    Then post number 6 does it for you hilda, one USB one end and mutiple ends the other a wide choice to cover most of what you need, a usefull kit, one ordered.
    <Multiple end USB kit click here>
  17. Munchie
    Jul 28, 2007
    8,579
    11,816
    I have never seen one of those before:Blush:
    I would be concerned though if you attached multiple devices would they all work correctly bearing in mind as i said some devices do not even like hubs? :Doh:
  18. hilldweller
    Dec 5, 2008
    27,314
    26,305
    Macclesfield
    Only for charging !
  19. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,141
    Welsh marches
    if only for charging, then the multi end does it
    If for data connection then the USB hub is the only real option
    Perfect solution doesn't exist yet that im aware of, but i would love to be corrected on that
    Even the so called standards arent always the same, mini USB as an example, some manufacturers change around the data pins so they dont work with others using the same type of port...gits!:Angry:
  20. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    fair enough why else would you need to connect.
