Urgent help required -- Newbie in France
Discussion in 'Motorhome Chat' started by moulin 87, Jul 10, 2016.
  1. moulin 87
    moulin 87 Funster
    Aug 31, 2015
    235
    419
    Limousin, France
    Hi Picked up the new motorhome yesterday in Villeneuve sur Lot, everything was going OK until......
    I decided to switch on the TV to watch the tennis etc. when the satellite dish on the roof which was already up and 'locked' onto Astra 2 (or so I thought) moved around and the LNB has now wedged against an open rooflight and of course stopped..It is not possible to move the arm back, it is quite rigidly locked and the rooflight is fully open ....
    Either as a safety measure or because a fuse has blown there is no lights on the sat system...
    I think it will be possible to undo the screws holding the LNB but at the moment we are in full sun at 32C....
    IT is a Teleco Classic system.
    Any ideas would be appreciated....
    • Like Like x 3
  2. pyro
    pyro Funster
    May 8, 2016
    799
    1,886
    silver coast, portugal
    I would try removing the LNB (but not disconnecting) and substituting the fuse, then getting dish to move. Do not force it
  3. hilldweller
    Dec 5, 2008
    26,898
    25,747
    Macclesfield
    All I can do is say "Congratulations". To the best of my knowledge you have a totally new fault and in the tradition let it be named the "Moulin Disaster".
    Quite an appropriate name when you think about it.
    If you take the above advice make sure that if the dish closes or rotates the LNB etc is not going to get trapped.
    • Funny Funny x 2
    • Like Like x 1
  4. moulin 87
    moulin 87 Funster
    Aug 31, 2015
    235
    419
    Limousin, France
    The arm has been released from the skylight but the dish is not moving so there is an 'electrical' fault somewhere, I'll be going through the fuse box looking for a blown fuse, any other ideas???
    Thanks in advance
  5. Stonemags76
    Stonemags76 Funster
    Aug 14, 2011
    124
    78
    Derbyshire Dales
    That happened to us, but we ended up with a cracked roof light after some "forceful" manoeuvres! If you can get on the roof, hubby says you can loosen the nuts holding the dish onto the base plate just enough to allow you to close the window.
    Posted this before I read you had freed it.
  6. Stonemags76
    Stonemags76 Funster
    Aug 14, 2011
    124
    78
    Derbyshire Dales
    I think we pulled the fuse out, left it for a while and put it back in in order to re set the dish?
    • Thanks Thanks x 1
  7. Stonemags76
    Stonemags76 Funster
    Aug 14, 2011
    124
    78
    Derbyshire Dales
    Or turn on the ignition and see if the dish comes down?
    • Thanks Thanks x 1
  8. Big Nick
    Big Nick Funster
    Aug 17, 2015
    259
    286
    Yorkshire
    Glad I got a Camos!!
  9. moulin 87
    moulin 87 Funster
    Aug 31, 2015
    235
    419
    Limousin, France
    I've replaced a blown fuse in the control box and tried starting the engine but without any joy....Looking now for blown fuses at the main fuse box...
    Thanks again
  10. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,613
    11,288
    Taunton Somerset
    It is an installation fault speak to the dealer on Monday and let them deal with it
    • Informative Informative x 2
    • Like Like x 1
    • Thanks Thanks x 1
  11. moulin 87
    moulin 87 Funster
    Aug 31, 2015
    235
    419
    Limousin, France
    As it is France , they are not open until Tuesday!!! I've replaced the one blown fuse I could find so as you suggest we'll have to wait until Tuesday!!!
  12. scotjimland
    Jul 25, 2007
    28,936
    25,589
    that's a polite way of saying it's a complete balls up ..
    the dish should be fitted so that it can rotate 360 deg without hitting any roof furniture or open roof lights.. Whoever fitted it should be bull whipped..
    if it has happened once it will happen again.. take it back and insists it is re mounted correctly..
    • Like Like x 5
  13. hilldweller
    Dec 5, 2008
    26,898
    25,747
    Macclesfield
    They will love that, holes to drill, holes to fill.
    But unless an electrical interlock could be fitted it is the only safe way.
  14. scotjimland
    Jul 25, 2007
    28,936
    25,589
    not necessarily..
    it may only be fixed with Sikaflex, that's all I used to fit mine.. no screws .. so could be removed with cheese wire.. and the same cable entry could be used..
    clearly the installer didn't have a clue or didn't read the fitting instructions ..
    just my opinion
    • Like Like x 2
  15. jtp890
    jtp890 Funster
    May 16, 2014
    285
    222
    wakefield
    congratulations on buying a dethleffs, good investment.
    • Like Like x 1
  16. moulin 87
    moulin 87 Funster
    Aug 31, 2015
    235
    419
    Limousin, France
    Update...
    Only had a 2 amp fuse and a 7.5 amp fuse spare, it was a 5 amp which blew, just as Andy Murray won I tried again with the 2 amp and the dish closed but again lost power, checked 2 amp fuse it was blown, is it OK to check with 7.5 amp fuse...
  17. Chipster
    Chipster Funster Life Member
    Oct 15, 2013
    396
    242
    East Midlands
    I would, but I appreciate I'm not there. However if a 7.5a blows there is definitely something wrong but also you need to try and sort it. Chances are you've blown the fuse as a result of the stall. Replace with a 5a when you can and enjoy your van.
    • Thanks Thanks x 1
  18. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,909
    notloB
    A 7.5 should be ok if there isn't a fault, the 2amp may not have been big enough for the current needed to move and park the dish. 5 amp asap though.
  19. moulin 87
    moulin 87 Funster
    Aug 31, 2015
    235
    419
    Limousin, France
    Found a guy on the site with a spare 5 amp fuse, seems to be working again but will take it to dealer on Tuesday..
    Thanks for your help...
    • Like Like x 7
  20. hilldweller
    Dec 5, 2008
    26,898
    25,747
    Macclesfield
    FUN wins yet again.
    • Like Like x 2
