Urgent help please re omnistor awning
Discussion in 'Motorhome Chat' started by Goldilocks40, Oct 14, 2013.
  1. Goldilocks40
    Goldilocks40
    Sep 18, 2013
    38
    8
    Gloucestershire
    Hi friends
    Does anyone know if an Omnistor 5003 awning has a 4mm or a 6mm channel for attaching a porch awning? Am about to order one but need to know if I need figure of 8 tape so will attach, have tried measuring van channel but too difficult to see and Internet and paperwork doesn't say.
    cheers
    Dawn
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,178
    14,108
    Bolsover, Derbyshire
    I can't answer the question, but we have just bought a Kampa awning and it fits straight into the rail on our Omnistor
    David
  3. Goldilocks40
    Goldilocks40
    Sep 18, 2013
    38
    8
    Gloucestershire
    Thanks David, have just ordered a kampa one too :Smile: going away Friday so not a lot of flex to get tape if needed.
    Dawn
  4. Jim
    Jim Ringleader
    Jul 19, 2007
    26,840
    79,215
    Sutton on Sea
    The Kampa one that I have comes with two sizes, sewn next to each other so that it will fit 99% of awning channels.
  5. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Omnistor has a 6mm groove, Fiamma 4mm groove, kampa has both beads to fit both types. Pete
  6. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,178
    14,108
    I hope it turns up in time, a word of caution, I snagged our new awning pulling it into our Omnistor rail, the opening had a rough finish that I did not spot, worth having a look and maybe use a small round file before you first use to smooth the inside.
    David
  7. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    I have been known to rub a bit of Butter in the groove to ease the slide, it also helps if somebody holds the awning up to give a straighter pull. Pete
  8. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    A spray with silicone lube is good and, I have put an eylet in each end of awning 'tape' so that we can attach a strap which Carolyn puts gentle pressure on as I feed awning in :BigGrin:
    One thing I forgot-I have fastened an aluminium awning rail just below our Fiamma awning-this gets porch awning really close to van
    Mike
    • Like it Like it x 1
  9. Lindylooj
    Lindylooj Read Only Funster
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Just a quick question on the back of this one, we bought a Kampa and yes as everyone says it will fit both. My question is does anyone have a solution to stop draughts from bottom of van as our Autotrail doesn't have a channel to fit the skirt that came with the awning.
    Thanks :Smile:
  10. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    Er,sorry to say this,but you need to fit a channel or get one fitted :BigGrin:
    Mike
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,178
    14,108
    Mike[/QUOTE]
    Great idea, I am concerned that we might have put some strain on our Omnistor awning, hanging the Kampa from it, even if only extended by a couple of feet. I seem to be having trouble winding it back in now with or without the Kampa awning attached.
    David
  12. SteveandDenise
    SteveandDenise Funster
    Sep 26, 2011
    583
    737
    Spalding LINCS
    Skirt
    We put some eyelets in the skirt then bought some small silicone suckers from Jezport they hold it fine.
    I think he trades as Parrot-Sol
  13. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    H
    I what I have done on my last two vans was screw a rail underneath your van skirt then run a caravan skirt along best have one a bit longer than your awning so has to rap around the side of the awning to finish off. Pete :thumb:
  14. Lindylooj
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Hi Peter, do you mean a rail with the channel in?
  15. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Yes a aluminium rail they come in a 4mtr length, I think then you cut to fit, they do work well, your van looks level right across so only the rear wheel to miss out, my van is up and down but still works ok with a bit of fiddling about. Pete
    Ps
    what I do is use a separate step so the leci step can stay in and saves messing about with cutting the skirt.
  16. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    Any chance of a pic or two Pete-I have put off addressing this problem because of doorway being lower than where skirt would run.
    Mike
  17. Goldilocks40
    Goldilocks40
    Sep 18, 2013
    38
    8
    Gloucestershire
    Thanks so much for all your advice you guys are brilliant :thumb: ordered from Johns Cross too and got discount, roll on Friday and our first trip :BigGrin::BigGrin::BigGrin:
  18. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    I will have a look into it Mike, If not ru in Marjal next year. pete
