Urgent help please Electric step not working
Discussion in 'Motorhome Chat' started by Spidey, Aug 12, 2016.
  1. Spidey
    Spidey Funster
    Jun 16, 2013
    837
    556
    Wiltshire
    Our electric step has stopped working. We need to leave the site in an hour. We are on the ferry tonight as well. We can drive to just outside the campsite and park up.
    The step wouldn't retract and now when u press the rocker switch it sounds like it's trying. The step can be pushed in manually but won't stay in. Could it be the fuse? And where would that be? If not would it be all right to try and tie the step up under neath? The warning buzzer may go off in the front cab and not sure what damage we would do.
  2. Teuchter
    Teuchter Funster
    Nov 4, 2014
    461
    1,478
    Lee on the Solent
    Remove the fuse and push the step in - that should work.
    • Thanks Thanks x 1
  3. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    722
    4,132
    Chelmsford Essex
    When mine went t*ts up this week, it was the little switch on the step itselfnot working. Cleaned it up squirted WD 40 made sure it had a clean connection and bingo it works.
    Not the worlds best design....a small pressure switch sprayed with mud and sh*t, not surprising it malfunctions.
    Plan B could be remove the step fuse from the van,push the step up and fix with a cable tie or similar.
    I have a schaudt Ebl99 electric box and the fuse is on there.
    Good luck..
    • Thanks Thanks x 1
  4. Spidey
    Spidey Funster
    Jun 16, 2013
    837
    556
    Wiltshire
    Thanks for the replies. We can tie the step up so hopefully that will get us home. Sorry for sounding stupid but where is the fuse for the step? So many fuses not sure which one. The connection underneath looks clean.
  5. chaser
    chaser Funster
    Feb 16, 2013
    7,279
    7,979
    uttoxeter
    Can you just pull the wires off to it
  6. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,647
    10,470
    Glasgow
    Sorry I cant help but you might be able to help others to help you more if you give details of your MH.
    Hope you get home safely.
    • Like Like x 1
  7. Spidey
    Spidey Funster
    Jun 16, 2013
    837
    556
    Wiltshire
    Sorry good point. Hymer tramp cl 554.
    Hubby managed to tie it up and stop the buzzing. Dealership going to get an engineer to phone is just in case it's an easy fix.
  8. SandraL
    SandraL Funster
    Jan 24, 2012
    249
    138
    Somerset
    If the switch on the step is like mine try googling "switch 51840"
    Set to images and see if its the same. Its a car courtesy light door switch and less than a fiver but wont come with the rubber boot. Mine was intermotor brand and has www.premier-factors.com on the box. Good luck. Came from ebay....
    • Like Like x 1
  9. Spidey
    Spidey Funster
    Jun 16, 2013
    837
    556
    Wiltshire
    All sorted for the journey home. Step tied up and our dealer phoned us to tell us which wires to pull. This stopped the warning buzzer going off. Will get it fixed properly when home
    • Like Like x 2
  10. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,875
    1,624
    Bungay Suffolk
    Ask Jaws. :rolleyes::rolleyes::rolleyes:.
