Urgent help needed - no power in 12v system
Discussion in 'The Beginner' started by Touchwood, Feb 9, 2012.
  1. Touchwood
    Touchwood Funster
    Aug 23, 2011
    749
    713
    NE England
    Help!!
    We're going on our first trip of the year tomorrow. Just picked up the van from storage, checked the 12v system and zilch - couldn't get any habitation lights on at all.
    The van has been in storage but I've been giving it a 10 mile run every couple of weeks, and just last Friday we had a run to Whitby - around 60 miles round trip I guess - and didn't use the aux battery at all. The engine battery seems fine.
    I've taken the auxiliary battery out and put it on charge - I got a reading of 8 volts from it on my meter - I know this is low but I would have thought enough to raise a dim glow in the habitation lights? I'm concerned something else may be wrong - perhaps a fuse?
    Any advice welcomed - even if I don't get sorted we're going anyway, we'll be on EHU so I'm assuming habitation lights will work when we have mains power on - but if not we're in trouble. Difficult to check beforehand, I have an EHU lead with an ordinary mains plug on but it's difficult where I live to get it plugged in without trailing wires across the pavement.
    Looking forwar to you invaluable assistance :BigGrin:
  2. hilldweller
    Dec 5, 2008
    26,909
    25,761
    Macclesfield
    If you haven't got a charger that will recover it it's kaput. Probably kaput anyway.
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,215
    7,337
    Nr Watton in Norfolk
    I would think if it was down to 8v it is probably kaput
  4. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    hi in some cases the hab control panel wont switch on unless the battery is above 12 volts dont know if this is the case in yours but i do know that a lot are like this.
  5. mikkidee
    mikkidee Read Only Funster
    Aug 1, 2010
    289
    227
    Malton,North Yorks
    If ya battery is showing 8v then it will probably need replacing
  6. mikkidee
    Aug 1, 2010
    289
    227
    Malton,North Yorks
    Don't know where you are in the NE but there must be somewhere to buy another battery.
    It'll sa e ya weekend:Smile:
    Mike
  7. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    "No probaly about this" i am sorry to say 8volts its dead and burried. :cry:
  8. Touchwood
    Touchwood Funster
    Aug 23, 2011
    749
    713
    NE England
    Thanks all - I do have another auxiliary battery, in the van but not wired up. I'll check that out if the old one won't recharge.
    What's caused it to go kaput? Is it that I haven't kept it charged? I had a leisure battery on my boat that held charge all winter with no problem.
  9. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    if a battery goes flat and is left flat then depending on the lenght of time you can kill it off.:cry: how old is it? if its nothing special and over 3 years its probably on borrowed time anyway.
  10. hilldweller
    Dec 5, 2008
    26,909
    25,761
    Macclesfield
    Presumably something is discharging it or else plain old age and self discharge.
    Maybe an alarm or radio. You need to try an ammeter before you connect both terminals when you re-install.
  11. Touchwood
    Touchwood Funster
    Aug 23, 2011
    749
    713
    NE England
    Now I'm more puzzled, after just 20 mins on battery charger battery is now showing 13v.!
    Any ideas?
    Off to check spare battery.
  12. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    Might be worth dragging the mains cable out over the pavement and make sure everything is still ok on hook up as well.
    You don't want to go away and find nothing is working on either of the 12v or 240v systems.
    Callum
  13. Touchwood
    Touchwood Funster
    Aug 23, 2011
    749
    713
    NE England
    All works fine with spare battery, so will manage with that for the weekend. I'll try reconnecting the old battery when we come back. Still puzzled as to why it now says 13v. I'll check it again in the morning - if it's down to 8v again I'll know it's dead.
  14. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    Hi again,, seems strange as you say . but 8v to 13 in 20 mins is somew going check the voltage in a couple of hours to see if it is dropping as quick as charging.
  15. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,337
    34,816
    If the voltage meter in your van is the same as we had in our Elddis then it might be telling lies. I never had the battery down as low as 8 volts on the meter but on a couple of occasions it was showing a low reading even though the indicator was still green. So, checking after you come back will be well worth it.
    If you do have to buy a new battery both Hadrian at Thornaby and Autoplus at Norton have reasonable prices. The only other place I know locally for leisure batteries is Teesside Caravans but I've never had occasion to check their prices.
  16. Touchwood
    Touchwood Funster
    Aug 23, 2011
    749
    713
    NE England
    Graham,
    I wasn't using the voltmeter in the van, I was using my multimeter. The voltmeter in the van wasn't showing anything at all, I assumed that as no power on it wasn't working.
    Thanks for the advice on where to get a new battery, looks like I might need to invest - I'll be seeking advice on that as well in due course.
  17. harryoxford2
    harryoxford2 Read Only Funster
    Sep 14, 2010
    559
    255
    Bishops Stortford Herts
    If you get a desuphater charger you can probably throw the build up on the plates off and it will accept a charge.
    I have recovered 3 batteries that way. It takes about 48 hours to recover the battery to tip top.
    If you go this route Ill send you the link. The desulphater charger has to be big enough to cope with the amp/hours of your battery as if the charger is too low an amp/hour rating then it will only trickle charge.
  18. ramsthom
    ramsthom Funster
    Nov 23, 2011
    144
    89
    durham
    If was only 8volts after a 60 mile run last week i would suspect the inline fuse near the leisure battrey has blown. This sometimes happen if the battery discharges when in storage. When the motor is started the chargling amps to the leisure battery is too high, blowing the fuse. I think its 20 amp rating.
    • Like Like x 1
  19. GJH
    Aug 20, 2007
    27,337
    34,816
    Too technical for me. I just crossed my fingers and plugged in the EHU :BigGrin:
    • Like Like x 1
  20. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    89
    Plymouth
    Replacement Bty
    Mine may need replacing too but will have to see an "Expert" to advise me. The Elecsol 100 amp carbon fibre bty has been recommended and at a price of £93:Eeek: seems a bit high but it has a 5 yr guarantee so probably worth it Anyone have one off these and what are your views etc:Smile:
