Upgrade from 3.5 (?)
Discussion in 'Motorhome Chat' started by Scattycat, Jul 5, 2014.
  1. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    Can someone advise me on what we need to do to up grade our MH to 4 or 4.5 tonne?
  2. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,142
    Welsh marches
    depends on what chassis your van is on, and what limits that has before you have to start adding extras like bigger wheels, air suspension etc
    • Like it Like it x 1
  3. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,125
    8,358
    Forest of Dean
    http://www.svtech.co.uk/motorhomes.html
    Contact SV Tech and fill in the form on the attached link, pick the one that applies to your van
    SV Tech will then reply telling you if its possible and what if anything needs to be done to the van to comply.
  4. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,599
    7,882
    Is it not French registered ?????
    That could change things a lot....
    Stop messing about, sell it and buy my Autotrail.. :wink::rofl:
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    Hi Scatty
    Is your Citroen on 15 or 16" wheels
  6. Techno
    Jul 28, 2010
    14,187
    15,162
    Have a look at your Alko tag in front of the rear axle.
    Example see my axle is capable of 2400kg regardless of plating
    I imagine yours is much lower but will give an idea
    [​IMG]
  7. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,806
    1,027
    Cark, Cumbria
    If it's not on 16" wheels then 3800kg is about as far as you can go.
    Mine is on a Fiat chassis(i.e. not Alko) & I am just upping it from 4000kg to 4500kg.
    Needed Air assistance on rear suspension & optional rear tyre upgrade to 225 75 16 (221 rated)
    to increase rear axle to 2600kg from 2400kg.(front axle 2100kg).
    • Like it Like it x 2
  8. elamessa
    elamessa Funster
    May 20, 2009
    508
    480
    Haute Vienne, France
    No good doing that, the steering wheel is on the wrong side.
  9. elamessa
    elamessa Funster
    May 20, 2009
    508
    480
    I have looked into this Mike and it seems that you must contact your MH manufacturer (Rapido!!) and ask them to supply you with a COC with the uprated weight, should be ok with the ALKO chassis, once you have this it's a case of visiting your Prefecture armed with your Grey card, proof of address, inside leg measurement etc etc, (you know what the french are like for paperwork) and you should walk away with an updated Grey card with uprated weight.
    Works in theory. If all fails a visit to the local Drire/Dreal is your next option.
    Good luck.
    Steve
  10. Techno
    Jul 28, 2010
    14,187
    15,162
    There are a number of different weights of alko and if it's not a heavy chassis like mine which are usually a special order there is no way to overcome that.
    As said the wheel size is a very big clue
  11. elamessa
    elamessa Funster
    May 20, 2009
    508
    480
    I don't know what weight of alko chassis Mike has on his van or what size wheels, I was just giving him information on upgrading his MH in France.
    I also forgot to add Mike that if you are successful in upgrading then you will need a CT (mot) every year in stead of 2 yearly you will also need a medical after your 60th birthday.
  12. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    Hey, ho,
    Thanks for all the info, but after due consideration, I think I'll leave it as it is.
    If I upgrade it will only encourage me to carry even more stuff that I don't really need. LOL:)
