Unslung gas tank
Discussion in 'Tech/Mech General' started by rich g, Oct 24, 2015.
  1. rich g
    rich g Funster
    May 29, 2014
    243
    357
    Worcester
    On my A/S Warwick the gas tank underneath has paint peeling off and surface rust,what paint would be best would it be something like stone chip.
    Rich
  2. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    Assuming it is only light rust you can do something with it. To start off then off the tank valve. Carefully scrape any loose material off the tank then gently wire brush it to remove the surface rust, a brass brush is safest as it won't cause sparks. I'd then prime it with either an etching primer or hammerite primer. Top coat with a good quality metal paint. Finally give it a couple of coats of rubbberised paint (stonechip). Check the tank mounting closely as AS gang their tanks in thin metal straps.
    D.
  3. xsparks
    xsparks Funster
    Mar 11, 2013
    149
    73
    Gillingham
    I did mine last summer.I removed the tank wire brushed all over and gave it a coat of rust remover and then painted it with Hammerite , when that had dried I gave it a good coat of under seal. Should last for years now.
  4. dave newell lvs
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    Apologise for the speelung orrers in my previous psot, I was on my phoon and preductiv taxt took ever.
    D.
    • Like Like x 7
  5. rich g
    rich g Funster
    May 29, 2014
    243
    357
    Worcester
    :LOL:
    Thanks for your helpful replies.
