Universal Water Pipe
Discussion in 'Motorhome Chat' started by bernardfeay, Sep 12, 2014.
  1. bernardfeay
    bernardfeay Read Only Funster
    Nov 18, 2009
    575
    825
    Bolton
    Has anybody figured out the most universal pipe end that can adapt to fit on the majority of different taps in UK and Europe.
  2. phase3begins
    phase3begins Read Only Funster
    Jul 1, 2012
    281
    317
    Nr Whitby
  3. BreweryDave
    BreweryDave Funster Life Member
    Aug 10, 2011
    1,620
    3,783
    Torre Del Mar - Malaga
    • Like Like x 1
  4. wingman
    wingman Funster
    Feb 10, 2013
    986
    2,492
    Romford, Essex
    Hi,
    In addition to the previous post and suggestion, get yourself a little box and keep a range. Most site taps need a screw-on adaptor which can come in two sizes. A trip to Bleedin Q or similar stores will have a range in the gardening section. The Europeans have all sorts of taps! These range from bog-standard domestic types - where you can use the connector pictured in the above post - to those with screw on terminations.
    It's not just a question of the adaptors either. It depends upon how far you are away from the tap! If you aren't on a 'posh' site where the pitch has its own service points, fill up with water when you enter the site. The reception staff will tell you where the water points are. (Fresh water is called Eau Potable in French). I always take a 5 litre canister (purchased from Icelands store) then re-fill it after that arrival cuppa. Or, get a larger plastic food grade 'Jerrycan' to save getting the filler hose out and moving the 'van.
  5. icantremember
    icantremember Funster
    Sep 2, 2010
    5,217
    7,338
    Nr Watton in Norfolk
    I don't think there is a universal fitting for all taps .... I carry a box with around 15 different connecters and have used most them at some point .... I have also still been caught out without the correct one at times :doh:
    P's. I am coming across more now that require a male Hozelock type end to push into a female outlet that start gushing as soon as you push it in.
