- Aug 18, 2014
- 23,765
- 133,481
- Transit PVC
- 16 years since restarting
So if you have a fixed tank the maximum litres it could carry of gas is 93L which is a tank size of 116.25L water capacity, but if you have a bigger tank it should not make a difference so long as the amount of gas it contains is no more than 93L.
as!
What I am saying is that there is a difference between the amounts of gas that you can legally carry depending on whether they are
one loose bottle = 93L of gas
Multiple loose bottles= 99L
one fixed container = only 73L of gas (80%)
Several fixed containers =79L of gas (80%)
You can carry more gas in loose bottles even though they are still at 80% of capacity as required by the regulations. You cannot carry 93 L of gas in a fixed container /tank.
Then again I've re-read it again & again & it is badly written.
This part states that you can carry 93l but then goes on to state & show on the chart that it can only be 80% full & indicates that only 73L would be accepted.
"Fixed gas containers (tanks, etc.)
For the purposes of this text, this means fixed containers that are permanently installed or fixed in a vehicle and are refillable from outside the vehicle.
The quantity of gas is limited to 47kg (or approximately 93 litres) maximum for a single container and to 50kg (or approximately 99 litres) maximum in the case of several containers. Each container must be no more than 80% full."
The chart then goes on to show that ONLY 73L would be acceptable -
I'm wondering if it means that a fixed tank with a capacity of 47kg/93L is the Maximum size they will accept & with a fill @80% 0r 73L ? Why else would they put it otherwise?
