unburnt fuel white smoke (1 Viewer)
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
the van is ruining but white smoke and diesel knock all the timing marks bang cant under stand it something i have missed ?
it has had complete rebuild
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
sounds like its fireing after tdc try retarding the pump a little,1 tooth perhaps:thumb:
43,319
49,396
black smoke....overfueling
blue smoke....oil burning.
WHITE SMOKE....WATER 'burning'
sounds like a head gasket leak Bill.
are you sure there isnt a hairline crack between cylinder and a water gallery or the same in the head.
did you have the head skimmed and pressure tested.
4,924
11,289
Flintshire
Low profile
since 2010
White smoke??, not been a new Pope elected has there:winky:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Does the white smoke smell dieselly Bill?
You'll soon smell the sweet smell of antifreeze if its water. Your pump timing might be out if it's diesel. Are the injectors known good ones? The fact she's knocking says compression is good so valve clearances are most like likely OK.
As mentioned previously, might be worth double checking your pump timing.:thumb:
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
It can be easy to confuse white smoke (unburnt diesel) & steam (usually coolant).
Smell the smoke. If it smells sweet it's coolant (glycol).
If it smells acrid & makes your eyes smart its fuel(diesel).
If it's knocking on one cyl suspect sticking injector.
If it's knocking on all, suspect timing advanced.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Some body told me once that their cat was poisoned by antifreeze.
If you sat a cat by Bill's exhaust, that would confirm whether the smoke was diesel or coolant!:thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Bill recheck your pump timing it does sound like could be too advanced
have a look here Link Removed
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
yes papajohn good test on it skimmed new bolt's it seem to be diesel just with the complete rebuild something not lined up right the pump was taken of all marked up punch marks
think it is just out one tooth ran out of light tonight will look tomorrow thanks for posting bill
Carol
14,050
112,111
North Wales.
Bill sorry no idea, but I have got my fingers crossed that you can sort it out tomorrow, Good Luck :Smile:
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
checked timing out one tooth buger
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Bill if there is a definite knock bleed each injector in turn ---simple job and if the knock goes then good if not then there is summat else possibly timing wrong or a duff injector
Just to encourage you, over the years I have re built about a dozen engines and never got any satisfaction from it
43,319
49,396
never experienced white smoke from incorrect timing as i never get timing wrong :winky::roflmto:
always checked the correct way.....set timing, turn two full revolutions by hand then check timing marks again. :thumb:
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
well this is only my second and my last
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
A blown turbocharger can also cause white smoke from the exhaust, it's usually fairly thick white smoke due to the turbo pressure, hope that helps.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
buckby
213
147
nottinghamshire
coachbuilt
Allways be careful when having head skimmed as when you torque the head bolts they can bottom out in the hole leaving the head loose but givving the correct torque setting we have had to grind the bolts slightly shorter before.
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
if you get a head gasket design for skimmed heads it takes up the slack
alleviating that problem
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
well she had her first test run went abut six miles before she cleared her throat by the tine i got back home the smoke had stooped and she is ruining good still knocking just a tiny bit just fine tuning on the pump but happy with the result's run her in now
never again till the next time
just run her steady for a few days
bill
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
a big thank you to every one who posted on this thread all your help was invaluable wat else would i expect from funsters
now looking forward to many happy miles of funster travails and adventures
bill
dogman
549
440
chepstow
Coach Built
I'm a newbie
Well done, another problem put to bed. Don't forget to change the oil and filter soon(ish).
Wildbill
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
will run it for abut 300 then change filter and oil but will keep an eye on oil condition thanks
got a magnet taped to sump plug
dogman
549
440
chepstow
Coach Built
I'm a newbie
Good man, you can monitor sediment with this, may get a significant amount of swarf first time but should diminish from there and also get finer.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Well done Bill
Well done Bill - I agree with above and will remember your name when my motorhome needs a rebuild. :thumb::thumb:
