baking soda/ soda crystals and vinegar works well in an ordinary bathroom
A MH is just like your home, standard plastic pipework, so if it works at home it works in MH.
That guy gets me, "don't use chemicals". So vinegar is, I think, acetic acid and other things, sodium carbonate is as chemical as it gets, an alkali. Mix it with an acid and it gives off gas and heat. Rant over.
But not your toilet, that has rubber seals, don't use bleach.
I like this idea! What size bottle?bottle of 'Comfort'
I was told on here not to pour boiling water down a sink...
Very true.That guy gets me, "don't use chemicals". So vinegar is, I think, acetic acid and other things, sodium carbonate is as chemical as it gets, an alkali. Mix it with an acid and it gives off gas and heat. Rant over.
Do you have a tip up type of sink?
Do you mean the bathroom sink in your Motorhome?
I recently resorted to removing the trap underneath mine as it was emptying very slowly.
It was gunged up with toothpaste slurry which took me a while to clean out. I think it's because we try to economise on water and the toothpaste doesn't get flushed through properly.
