Unable to see Speedo or Rev counter during Daylight Hours !! ?
Discussion in 'Auto-Trail' started by davidallan, Oct 7, 2016.
  1. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    Just impossible to see the above 2 dials without the Headlight On[ this then put on the illuminated dials -and All is OK ] NO illumination without the Headlight on. Whilst I do drive with them on a lot ..surely you should not be forced to ??
    So even on bright sunlit days those 2 dials cannot be seen.
    Remember the DRLs are ON anyway when the engine is running anyway.
    Unless I have not read any NEW laws regarding Headlights being ON always...
    [quite possible ] according to my wife !!
    All 'Funster' Topical comment most welcome please...(y)
    16 Plate Ducato Auto Trail T715 150
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,156
    1,885
    London
    Fiat Ducati chassis?
    Should have read all the post :(
    • Thanks Thanks x 1
  3. pyro
    pyro Funster
    May 8, 2016
    1,069
    2,891
    silver coast, portugal
    Lots about this on existing threads (use search). In summary
    Dipped headlights are legal
    Use existing GPS
    Get separate GPS speedo
    Fit LED on steering column
    It's a Fiat, you will learn to live with it and be glad of it in time
    • Thanks Thanks x 1
  4. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    Yup..Fiat Ducato chassis. Do point me in the right direction please and what is the Remedy ??
  5. pyro
    pyro Funster
    May 8, 2016
    1,069
    2,891
    The right direction is here: http://www.motorhomefun.co.uk/forum...-lighting-solution.120878/page-7#post-2041250
    You need to use the "Search" facility (top right corner) to look up other relevant threads
    I have summarised the only solutions I can think of above., you have to make your own choices I'm afraid. Be thankful you have a FIAT, though, whilst you may not see the speedo, at least you'll find it where you left it (obscure reference to the lack of security with Ford bases)
    • Like it Like it x 2
    • Thanks Thanks x 1
  6. stevec
    stevec Funster
    Sep 24, 2013
    616
    207
    Norwich
    See post #136 on link from pyro. Thats my solution. In test at the moment.
    Fiat do a software upgrade to put dash illumination on all the time. I believe you have to register for it. It has mixed reactions but largely negativei.e it is not effective enough. I've not had mine done yet.
  7. rangitira
    rangitira Funster
    Jun 30, 2010
    6,440
    13,418
    Cornwall
    Perhaps you need to adjust your seat, both up down/back, and if you have an adjustable steering wheel position, do that too. Complicates things, IF, you are tall.
    When we bought our present car I could not see the top of the speedo. It just needed the wheel and the seat adjusting.
    Same with our M/H
    I had to put more lean on the back of the seat, etc etc etc.
  8. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,758
    2,696
    Tunbridge Wells
    The Fiat upgrade can be got for free by phoning your local Fiat Pro dealer. They looked at mine to confirm I needed it and then I took it back later to get it fixed. That was because at the time they looked the fix was not yet available. Now I would think they will be able to look at it and fix it at the same time, because the fix is only a software update that keeps the dial lights on whenever the ignition is on. Better than before but still not perfect.
    I would suggest that would be your best bet to start with and then look at alternative home made cures if you are still not happy.
    • Like it Like it x 1
