Scout
- Apr 4, 2009
- 3,959
- 121,096
- chic c line
- 12 years motorhoming, a lifetime of living
Ok Its time to un mothball the mh, Ive done a pre check, check, everythings working ok and no leaks I can see so alls good to go
but I feel I need to clean the tanks, both fresh and waist as its been stood far too long,
when we had the C van I used to use a mild solution of milton in the fresh barrels, pump this through the system, leave in pipes for a few hours, then flush into the waist barrels, then flush thought will lots of clean water, Im presuming this will be the same for the M home, or is there a beter way,
I did intend to give the M home a run on bendy roads with the water is in the waist tank to lossen any crud
are there any chemicals I can put down the drains to help clean the tank out (such as SUPER WAIST TANK CLEANER) or is above ok
then I'll drain it all down again till we go away just in case of nasty mr frost
