tyres (1 Viewer)
APACHE 1988
43
123
WISBECH FENLAND
AUTOTRAIL APACHE
3 YEARS
Still getting van ready for first trip away since Denise was taken ill. While cleaning bodywork noticed one tyre had signs of the side wall cracking. Tyre did not look very old but I realise they can go down hill while parked up ( try and make sense of that please) Wrote down all that it said on tyre and went to our local Formula One for a quote. They said that they do not stock this particular tyre and could not advise me of what might do the job! Suggested I should look on EBAY but not that easy when you do not know what you are looking for. Anybody knowledgeable on tyres can advise if I cannot get "VANCO 215 R 14C 112 110VP" what would be a safe replacement? Apologies fr my ignorance once again.
Jun 29, 2015
3,411
56,109
Southampton
caravan (for now)
on and off since 1984
Search van tyres. Plenty of choice,
shop around for the best price
DBK
17,961
47,778
Plympton, Devon
PVC, Murvi Morocco
PP Bear
7,726
28,025
Kent, UK
Auto Trail Dakota SE
Used these, they were brilliant, totally professional and come to you to do the fitting :)
http://www.etyres.co.uk
I fitted Michelin Agilis, my life, my motorhome and peace of mind were worth it. They do all brands and have a discount on too. Good luck with whatever you go for :)
funflair
19,157
29,799
Guisborough
MORELO palace
since 2012
Hi APACHE
You are a bit short of numbers in the tyre description 215 -- 14 then 112 110 which is the load rating, the numbers you need in the middle will be 70 or 75, the first three have to be right for it to fit as this is the width and diameter, the load rating needs to be the same or higher.
If the tyre dealer you went to couldn't advise you, find another tyre dealer.
Martin
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Bit surprised if tyre is only a 14" would have thought .215 70 15 at the minimum....Roy
Aug 18, 2014
23,451
130,651
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Hi APACHE
Martin
It might not necessarily have a profile & just be
215 x14 . Mine have no profile & so are harder to obtain.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Maybe @Brian and Jo can help as they own a tyre depot and very helpful
funflair
19,157
29,799
Guisborough
MORELO palace
since 2012
OK good point thanks for keeping me right and apologies to the OP, so does that mean that they are a default 80 profile actually, that would make sense on 14 inch rims.
Martin
APACHE 1988
APACHE 1988
43
123
WISBECH FENLAND
AUTOTRAIL APACHE
3 YEARS
Put "EFFY" in for her MOT today knowing that one tyre should need replacing but fearing it could be 3. She failed, as was expected , on one tyre and a partly blocked window washer jet!! Not bad for a 28 year old.
Jan 20, 2015
179
169
Fife
Bessacar 454
Since 2013
Try Blackcircles , they will source your preferred tyre then send it to a local garage for fitting ,usually within 15 mile radius . All included in the price which will be be usually very competitive . Hope this helps
Ian
Jul 29, 2013
9,044
17,933
Salisbury
Hymer B678DL A class
since 2011
Another for Black Circles good prices and fitted locally
Aug 27, 2014
1,908
3,702
Shropshire
McLouis Tandy 640+
Since 2014
I normally use Black Circles or Tyre Shopper. However, looking for 2 new Michelin Agilis this week (5 year old Nexen rear tyres on van, one is just starting to show cracking between the tread in one place :() I actually found, to my great surprise, that Kwik-Fit online was the cheapest for my size. Fitting at Kwik-Fit or they send a fitting van to you.
APACHE 1988
APACHE 1988
43
123
WISBECH FENLAND
AUTOTRAIL APACHE
3 YEARS
took some advice from BRIAN + JO.....2 Hankooks being fitted Monday and
for the first time I will have a decent spare!!
