TyrePal on 2014 Fiat Ducato Motorhome with Alloy Wheels Question
Discussion in 'Motorhome Chat' started by zac, Jul 19, 2016.
  1. zac
    zac Funster Life Member
    Nov 19, 2013
    732
    242
    Hampshire
    I have an Autotrail Delaware which is a 2014 (x290) Fiat Ducato base, this has alloy wheels and i know there is a concern about fitting the Tyrepal Sensors to certain valve types. Does anyone know if ours is suitable to take such a system as the valves on our tyres look metal but not sure to be honest.
    I have the tyrepal system already as originally used it on the hydratrail only but that is now sold so thought i might use it on the MH and a trailer when i get it?
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,185
    14,955
    Leeds the one up North
    No problem at all
    Whether alloy of steel wheels it's still a steel valve and the sensor simply replaces the dust cap
    • Informative Informative x 1
  3. zac
    Nov 19, 2013
    732
    242
    Hampshire
    Great thanks, sure i read in the manual about it shouldnt go on a certain type of valve, i will sort this out then
  4. TerryL
    TerryL Funster
    Mar 5, 2010
    1,357
    1,335
    North East
    Not sure what type of valve the instructions mentioning this refer to, but provided you've got proper metal valves - which you should have given the high pressures m/h tyres run on - there's no problem with TyrePal. Works okay on mine.
    • Thanks Thanks x 1
  5. Borderland
    Borderland Funster
    Nov 5, 2014
    422
    2,317
    Borders
    Can't use them with aluminium valve stems.
  6. zac
    Nov 19, 2013
    732
    242
    Hampshire
    That was it, i am assuming from previous posts that the 2014 fiat ducato doesn't have them.
  7. Techno
    Jul 28, 2010
    14,185
    14,955
    I doubt you would find any commercial vehicle with aluminium valves
  8. zac
    Nov 19, 2013
    732
    242
    Hampshire
    Thanks, good to know as i have no idea about these things.I brought the Motorhome version of tyrepal over a year ago but have only ever used 2 sensors from it for the hydratrail thinking i couldnt use them.What a fool :(
    Thanks anyway, i will fit these later,probably find they dont work now lol.
