Tyre wear on towed car
Discussion in 'Tech/Mech General' started by williat1, Apr 13, 2010.
  1. williat1
    williat1 Read Only Funster
    Jan 30, 2008
    25
    Pontrhydyfen, South Wales
    Hi,
    I tow a Fiat Panda on an A frame behind my motorhome. I have had the car since new and it has covered 8000 miles with about 600 miles on tow.
    The car had it's first service today and I was advised that the inner surface of the front tyre tread on both wheels was down to 3mm whilst the rest of the tread was 5mm.
    My question is .... could this inner wear be due to towing or is it most likely to be due to a tracking problem? I'll get it tracked next week....... but has anyone else experienced uneven tyre wear on towed vehicles.
    Regards
    Williat1
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    As far as I am aware, vehicle tracking/toe out, is set to take into account that, in the case of a Front Wheel Drive Car, the wheels are being driven by the engine...
    This is not so with a toad..
    Excess wear on the inner surfaces suggests a tow-out maladjustment.
    8000 miles is well under what is to be expected from a pair of front tyres.
    I'd get the wheel alignment checked first and, if out, argue the case based on that.
    Has anyone else had this problem?
  3. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,440
    2,534
    UK / Spain
    Hi, we never had a problem with ours, have you made sure the steering lock is off. :Smile: Bob.
  4. williat1
    Jan 30, 2008
    25
    Hi Bob,
    Yes steering lock always off. I was wondering if the absence of power steering on the toad would put extra scrubbing on the tyres?
    Regards
    williat1
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,691
    5,845
    Mansfield,Notts
    I'm of the opinion that the wear has been caused by incorrect tracking
    wear caused as you suspect would be more evident on the outside eges
    Geo
  6. Braunston
    Braunston Read Only Funster
    May 21, 2008
    1,415
    7
    Hi,
    I had the same problem on the first service (12000) on our Panda Multi jet, had the tracking checked and the first chap couldn't find any problems, the second place I took it to suggested it was only out by a degree and not really necessary told him I wanted it adjusted which he said he did, had some Budget tyres fitted and 47000 miles later just had them replaced again even though they still had some life in them.
    I really think it was the energy tyres that were fitted that were not that good on mileage, no real reason just a gut feeling.
  7. craiggs
    craiggs Read Only Funster
    Feb 20, 2010
    67
    i would say its the camber angle or the tacking they should check both and tell you i went to bush tyes it will need doing asp now you no
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    agreed steve "the wheels are being driven by the engine"... which will take up any play in joints/bushings etc when driving but the tracking would need to be more than a couple of mm 'negative track' to scrub the inside of the tyres in 600 miles.
    with all certainty its the 'normal' tracking that out.
    i would say, if anything, the frame would cause the outside tread to scuff due to sideways pulling forces when cornering.
  9. IrasciBill
    IrasciBill Funster
    Mar 6, 2010
    186
    19
    SW Scotland
    Tyre Wear
    Whilst I agree with much that has been said above, I think the most likely reason is the energy tyres as a previous post said. SWMBO has a Fiat 500 which has done fewer miles than your Panda and the front tyres need to be replaced. The wear is not uniform either, although the car has never been towed. My local tyre guy says the energy tyres don't last as long as ordinary tyres! :cry:
  10. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Pardon me for suggesting this but, doesn't this rather defeat the object of a greener environment!
    Correct Pressure and Tracking must be the most vital adjustments regarding regular tyre wear across the whole width of the tread.
    I had to laugh at this ad for the tyres.
    "With MICHELIN EnergyTM Saver, you can benefit from Michelin's recognised longevity. Longer-lasting tyres also result in fewer worn tyres to recycle."
  11. IrasciBill
    IrasciBill Funster
    Mar 6, 2010
    186
    19
    SW Scotland
    Tyre Wear
    Yes, totally agree with you! Tyre guy says that the rubber compound used to achieve lower rolling resistance is the reason for the rapid wear. As for the Michelin advert, our experience is that tyres needing to be replaced at just over 6500 miles is not exactly "longevity". I used to use cheap, East European tyres on my last car and could get about 36,000 miles out of them!
  12. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Cheers Bill,
    So that makes the purchase of these premium price tyres a bit of a nonsense then.....allegedly...as what you save in fuel costs is paid for in tyre purchase and more...:Doh:
    So that's a possible 5 or 6-1 tyre ratio based on the figures you mention...
    Steve.
  13. IrasciBill
    IrasciBill Funster
    Mar 6, 2010
    186
    19
    SW Scotland
    Tyre Wear
    Certainly seems that way to us Steve. SWMBO's Fiat 500 is fitted with Continental tyres and they are well in excess of £100 each. :cry: We'd need to save an awful lot of fuel with them to justify that cost - and the road noise from them is horrendeous anyway - so we're investigating the alternatives available. :Smile:
