tyre pressures
Discussion in 'Motorhome Chat' started by simontheturk, May 12, 2014.
  1. simontheturk
    simontheturk Read Only Funster
    Jan 14, 2010
    20
    8
    Hi can anyone through any light on this question...just had 4 new tyres continental camper tyres fitted
    215/70/r15 psi on side wall says 69psi but inside front door says front 72 rear 79
    Tyre company didn't know either.thankyou in advance
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,912
    10,285
    confused as to what the question is
    if its which pressure to go by, basically use the ones on the pillar till you know axle weights then use the table available in downloads. the max pressure on the tyre is relevant in the us only apparently. the fiat pressures are based on max load constantly but the tyre manufacturers will give a more precise pressure based on actual weight
  3. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,968
    2,341
    Lincs
    Continental's recommended pressures chart shows pressures ranging from 3 to 5.5 bar for those tyres, depending on which axle & what axle load.
    If you quote the max allowable weight for each axle I can tell you what the pressures should be for maximum load, which will give you an idea until you get a chance to get to a weighbridge. You should find those on a metal plate somewhere.
    I can tell you that Continental's recommended pressures are lower than what is in the doors, unless you are allowed over 2 tonnes on each axle.
