Tyre Pressures
Discussion in 'Motorhome Chat' started by laser101uk, Mar 13, 2013.
  1. laser101uk
    laser101uk Funster
    Jun 6, 2012
    335
    847
    Basingstoke
    Hi Guys
    I just bought a CI Mizar GTL Living on a Fiat Ducato 2.8 JTD which is 2005. Apparently the tyre pressures are all set at 79 psi which just seems a lot to me?
    cheers
    Steve
  2. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,812
    3,066
    Manchester
    Not sure what yours should be, it would be in the manual if you have one.
    Without checking i think mine are around 64psi.
    May have the pressures on the tyre sidewall.
  3. hilldweller
    Dec 5, 2008
    27,180
    26,154
    Macclesfield
    Our FIAT has stickers for about 75 all round. These are heavy vehicles. I think the sidewall says "Max 80".
  4. chaser
    chaser Funster
    Feb 16, 2013
    7,473
    8,408
    uttoxeter
    If you put normal van tyres on , do they have less pressure in them?
  5. Jim
    Jim Ringleader
    Jul 19, 2007
    26,325
    77,810
    Sutton on Sea
    Depends upon the tyre make and your weight. I have Avons that they suggest I run around 65psi but the Michelins on the same van were at recommended 80psi
  6. Brian and Jo
    Brian and Jo Funster Life Member
    Sep 24, 2007
    2,156
    4,178
    oswestry,shropshire
    Pressures
    Hi steve what size are the tyres,
    brian
  7. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i had different pressures recommended in the handbook to the stickers on the door pillar so emailed the customer services of the tyre company ( continental in my case) with the axle weights and the full details of the tyres fitted and within 24 hours they emailed me back their recommended pressures. :thumb:
  8. Roryboys Dad
    Roryboys Dad Read Only Funster
    Mar 19, 2012
    631
    804
    Glapwell Derbyshire
    We have Michelin 225/65 R CP tyres and the recommended pressures in the Manual are Front 3.8 Bar (55 lbs) and Rear 4.4 bar (63 lbs)
    These run very well with some warmth in the tyre after a long run, but not hot, and show no obvious sign of looking 'flat'.
    It will depend on the weight of your Motorhome (3500 kgs?), what type of tyre and size you are using and the axle weight on front and rear.
    This is typically what you should inflate to – Front axle 1850kg – 60psi / Rear axle 2120kg - 64psi – but that will still depend on the size and type of tyre.
    What size wheel and tyre do you have?
    Manufacturers usually recommend the highest tyre pressure that your tyres will safely take but this doesn't really work in the real world.
    Over-inflated tyres are as bad as under-inflated tyres in that they both cause problems and you should have your tyres as near to the correct pressures as possible.
    Try and ask at your local friendly Tyre depot, you must have bought tyres for your car/s before at a local dealer, and get their advice and help.
    The pressures you have at the moment are as high as you're ever going to safely get on your MH and the people who sell tyres locally are the ones you should have a chat with.
    :france::france::france:
  9. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    The tyre pressures on your van and in your manual are usually maximum values and could give you an uncomfortable ride. Get your axles weighed and e-mail your tyre manufacturer, asking for their recommendations.
  10. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    What is the weight on each wheel? That is the main determining factor, with the tyre construction having a smaller effect. 79psi sounds a bit high if you are under 3.5t, but still plausible. Most commercial wheels are rated to 80psi, but tyres are variable.
    Mine are around 55psi with about 900 kg on each wheel (6 of them).
    You can either look in the handbook, or calculate the wheel loading and look up the tables provided by the tyre manufacturer. Personally, I'd take the tyre manufacturer's suggestion over the vehicle's.
  11. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Click on downloads (LH side of home page)
    Click on tools
    Scroll down to tyres, click and all will be revealed:thumb:
  12. Rayb182
    Rayb182 Funster Life Member
    Nov 13, 2009
    1,485
    1,616
    Great Bentley
    We've got Michelin 225x75x16 and put 80 psi all round, that's what Michelin recommend
  13. duane0001
    duane0001 Read Only Funster
    Jan 18, 2013
    629
    389
    East Coast, North Yorks
    The max pressure stated on my tyres is 68, I run them near this, yes it gives a harsh ride but better fuel economy, but remember on soft ground or snow you will need to run them with less pressure to get good grip, I recommend always carrying a handheld pressure meter so you can release pressure with going too far, you will be amazed how much more grip you get with lower pressure in the tyres when the going gets tough
