Tyre pressures on tribute T615 (1 Viewer)
Alonsos
177
15
Devon Somerset border
Auto trail t615
Since 2008
just done tyre pressures few days ago on Autotrail tribute t615
On seeing what they were I got 54 psi on all 4 corners
So rang Fiat and 3 other places answer was do a few lbs less than manual says
Manual he say
Front 5.0 bar ie 72psi
Rear 5.5 bar ie. 79psi
Tyres are 215/70r 15cp campers
Having conversation in pub & a guy said that's a load of rubbish 72psi and 79 psi much to high for 3.5 ton vehicle
I tend to think it is a bit high , but argue about figures in Manual ?
What do you think ?
Jul 13, 2008
3,739
3,862
Low profile
As has been said before, get van weighed fully loaded including front and rear axles, then e-mail the tyre manufacturer, they will tell you the exact pressures.
Jul 5, 2013
11,726
13,705
Since 2013
I agree with BoringFrog. Assuming that they are Continental Campers, they will tell you exactly what the pressure should be for the axle weights you give them. They have tables for all sizes and types of tyres they make. They will be much lower that the very conservative figures used by Fiat and the converters. And when you reduce the pressures you will find that your fillings will stop falling out!
Keep a copy of their table in the van in case you are ever questioned by the police about tyre pressures.
