Tyre pressure
Discussion in 'Motorhome Chat' started by Jagtazman, Jul 3, 2016.
  1. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    Halifax, West Yorkshire
    I have a rapido 9097F with Avon 215/70R/15C 109/107 R tyres fitted.
    Anyone any idea what correct tyre pressure should be?
  2. PeteH
    PeteH Funster
    Nov 22, 2007
    2,125
    2,646
    East Yorkshire
    I run my CAMPER rated tyres at 5.5bar. But I suspect that a max of 55 to 60 psi will be on your tyre wall of NON Camper tyres?
    Pete
  3. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,015
    11,491
    East Sussex
    The only way tell is to weigh the van fully laden. Front wheels only, then rear wheels only. Only once you know the weight can you find the correct pressure.
    My 4.2 ton van only needs 3.25 bar in the front, which makes a massive difference to drive quality compared with the 5 bar that the van manufacturer recommends
    Once you know your weight you can email the tyre manufacturer and they will give you the correct pressure
    • Like Like x 1
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,133
    5,400
    Guisborough
    I wasn't aware that camper tyres ran higher than white van man tyres, I know our non campers run at 80 psi if you need to.
    The answer to your question though is take it to a weigh bridge to get axle weights and then contact Avon tyres.
    Martin
    EDIT oops too slow, again.
  5. Robert Clark
    Jul 12, 2014
    6,015
    11,491
    East Sussex
  6. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    Cheers will email avon I know the unladen Weight with full water and diesel and know what the max can be.
    Also know roughly what it should be fully laden but will receive take to weighbridge to check
  7. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,768
    11,826
    Kettering
    You need individual axle weights, not the total.
    The as Robert says you need to speak to the tyre manufacturer.
    No matter what anyone else might tell you this is the only way to get accurate pressures.
  8. PeteH
    PeteH Funster
    Nov 22, 2007
    2,125
    2,646
    East Yorkshire
  9. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,766
    11,971
    Plympton, Devon
    Good luck contacting Avon, they may give you advice but not all manufacturers will. Pirelli for example recently told a friend they couldn't advise and they should go by the vehicle handbook recommendations. The only manufacturer who seems to give detailed advice is Continental - but hopefully a few others do as well.
  10. ivorantony
    ivorantony Funster
    Jan 22, 2013
    507
    538
    London SE
    Michelin does as well, but just give the base vehicle type and don't mention it's a Motorhome,
    they are obviously under the impression that Motorhomes alway run around at Max vehicle weights or over :lipssealed:
    why they assume that I have know idea!
    but if you give Axel weights and Base vehicle type and of course tyre size and load rating then you will get sensible figures,
  11. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    Told them what I am loaded at and also what max axle weights will be if fully loaded. We will see will let you know if and when reply.
  12. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    Response recd:-
    With regards to your enquiry, we produce the 215/70 R15C 109/107R size in our Avanza AV11 range of Commercial van tyres. I think at this point, I need to make you aware that our Avanza range of van tyres are not marked “CP” – specific Motorhome tyres. They are “C” tyres – designed for usage with Commercial vans. The main difference is that the CP marked tyre is designed to be inflated to a pressure far in excess of our C marked Commercial van tyres. In saying that, we do get a lot of Motorhome users using our tyres and can advise on starting pressures for our tyres based on the information you’ve supplied.
    Should you wish to use our Commercial van product rather than an OE replacement marked with CP, starting pressures based on the max load of the tyre (1030kg), max pressure of the tyre (65psi) and gross axle weight you quote for your vehicle would be:
    Front: 1800 = 56psi, 1850 = 58psi
    Rear: 1900 = 60psi 2000 = 64psi
    These values are based on a single fitment rear axle. Please note the maximum inflation of the tyres must not exceed the maximum pressure of 66psi.
    I would also recommend that you advise your insurance company that you have “C” tyres fitted rather than “CP” tyres, as some do deem it a modification to the vehicle. Should anything happen where a claim would be needed to be made and this information wasn’t known to them, some may render the policy invalid.
    • Informative Informative x 2
  13. Dorwyn
    Dorwyn Funster
    Aug 19, 2013
    586
    315
    somerset
    My new pvc x250 was supplied by the dealer with Michelin Acuras with pressures of 70psi all round, which I found too jarring and uncomfortable. I have reduced them to 60/52, but I think they need to be reduced even more, but will check the axle weights beforehand. Some manufacturers state a max of 60 psi. It really seems a very grey and vague area. Since it is a pvc, I can't see that the insurers need to be informed that the tyres a type C.
  14. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    I was never asked by comfort about my tyres and I personally don't see a C being a modification over CP tyres.
  15. Robert Clark
    Jul 12, 2014
    6,015
    11,491
    East Sussex
    It would only be a modification if they are different from the original tyres
  16. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    Maybe each insurers views different. However when buying 2nd hand how do you know what original tyres were. You can only answer to the best of your knowledge. I am an insurance broker and I personally would not class other as a mod.
    On all the online quotes I obtained I was also never asked this question.
    It's a grey area tbh. Changing from steel to alloy has always been classed as a mod on old days but these days no issues
    Going from. 15 to 16 inch wheels would be a mod.
  17. Robert Clark
    Jul 12, 2014
    6,015
    11,491
    East Sussex
    I'd check with an authorised dealer as to the original tyre spec - or refer to the owners handbook
    Having the incorrect tyres could be dangerous and invalidate your insurance.
    Worth checking to be in the safe side
  18. Kevan
    Kevan Funster Life Member
    Jan 18, 2014
    700
    588
    Herne Bay
    I have Michelin Agila camper on my Rapido and was told by Michelin to put 80 psi in all round, so i run 80 psi on rear, and 70 psi front, works for me, when they get warm they show about 10 psi increase all round so 90 psi 80 psi.
    The reason they say 80 psi is they assume campers run heavy all the time, that's a quote straight from Michelin.(y)
  19. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,822
    1,711
    Cornwall
    My mate has just bought an Autotrail Savannah.
    He has previous as a caravanner but knows nothing about the finer points.
    We visited him on a site at Charmouth on our way back from Bagwell. He related that, when he picked up the 'van he asked what the tyre pressures should be.
    "Oh, 80psi" came the reply. So he drove it back from Newark (hint) to Cornwall and he was alarmed at the skittishness and the inability for him to hold a straight line.
    He then went to a Fiat Professional garage to be told that 80psi was too high and he should aim for 75psi.
    I went outside and examined his Continental tyres, (Camping), 225 x 75 x 16 Load rating 116 and there, on the side wall for ALL TO SEE!!! it said Maximum pressure 69psi.
    When I got home I did some digging and on the Continental Data sheet it states, with a maximum load (2100kgs front, 2400kgs rear) he should be putting 55psi on the front and 65psi on the rear.
    I've sent him a text and hopefully he will do something about it.
    Including, I hope, ringing up a certain Dealership in Newark and asking for the salesmans Gonads on a platter.
    • Like Like x 1
    • Useful Useful x 1
  20. Jagtazman
    Jagtazman Funster
    Jan 31, 2016
    323
    156
    Totally agree however tyres fitted by camper uk do you really see them fitting tyres which are not fit for purpose.
    The whole reason of the thread is to point out the importance of tyre pressure
    Tyres are often personal preference
    I regularly change my tyres own cars are generally the standard fits are not fit for the miles do
    I have read on this forum and several others that avon or hankook tyres are becoming the preference for lots of MH drivers.
    My tyres are almost new and a int changing them until needed
    I had a long conversation with camper uk and other MH dealerships over suitability of avon tyres and not once did anyone sat they are not fit for purpose. And no I did not ask Brownhills .........
Similar Threads
  1. Andysconcorde
    27
    723
  2. Touchwood
    15
    600
  3. Bart
    60
    2,126
  4. 2bob
    443
  5. Shrimp64
    29
    1,113
