Tyre pressure warning symbol (1 Viewer)
Melvin
230
182
Norfolk
Coach built
On & off since 1974
Had the tyre warning symbol come on today ,went to the garage and did all the tyres to the correct pressures but the warning light did not go off. Do I have to reset this in any way ?
This is a 2016 Peugeot 2.2
Any info would be gratefully received .
Nov 9, 2015
366
451
Shenfield, Essex
Carthago Malibu PVC
35+ years mainly in VW's
My wife has a VW Polo and we had a warning light come on. Checked the pressures and topped up the one which was a little low. The warning light was still on, so I resorted to reading the handbook :D The information on how to reset the warning light was there (y) I suspect that if you look at your handbook, there is probably a procedure documented in it
Trevor
Cal54
3,806
62,014
Southport, UK
Leisuredrive Renoir
Since 1996
There is no reset procedure on my 2014 Hyundai, but the warning light doesn't go off until you have driven approx 1 mile.
3
34127
Be aware that if the tpms is standard fit on the vehicle then it is part of the MOT test.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Some factory fitted tons are based on physical dimensions and there is a reset procedure.
Melvin
Melvin
230
182
Norfolk
Coach built
On & off since 1974
:unsure:Thanks for the replies ,there is very little in the handbook other than to inflate and if warning lamp stays on see a Peugeot agent.
