- May 7, 2013
- 845
- 1,353
- C Class
- On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
Hi Guys,
Fitting a TyrePal today on the MH and not being able to find any guidance on tyre pressures for the new to us Lunar Roadstar 620 I decided to check the tyre pressures Marquis had set it up with. I was surprised that the front tyres are set at 73 psi and the rear 80 psi . I had expected the higher pressure to be on the front axle.
Am I being stupid(which is highly likely as I usually am!) expecting the axle carrying the engine to require the greater tyre pressure?
I am aware that I need to go to a weighbridge to be able to calculate the required/correct pressures but just wondered if I got the principle incorrect.
Look forward to your guidance --thanks again
Ian
Ian
