Tyre Blows On Motorhome (1 Viewer)
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Slight injuries to driver and passenger in RV which stopped on it's side
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Looks like a good reason to invest in a tyre monitor system.
Anyone use a Tyrepal and is it any good?
Been thinking of one for a while so should I go for it?
Richard.
funflair
19,343
30,217
Guisborough
MORELO palace
since 2012
We have it, and like the sense of security it gives, works well.
Martin
Feb 24, 2013
13,083
101,446
Bolsover, Derbyshire
Hymer S800
not long enough
It really cant help sticking a 4 ton pendulum on the back though
We never get to hear the age of the tyres involved in these blow outs, it would be good data for all of us scared / prompted into a 5 year change :)
I have no idea if the Americans change tyres on this same basis as us and cant easily tell the age of the RV involved
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Richard.
we have it and I'm pretty sure it can help along with regular inspections and maintenance
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I have a Tyrepal kit on mine. Maybe by monitoring the pressure and temperature of the tyre, a blowout could have been avoided.
Of course, we don't know the age or condition of the affected tyre.
Allan
9
9526
As we don't know what caused the blowout, it's difficult to say whether tyre monitoring systems would have prevented it.
One thing we can say with some confidence is that a lower speed and the lack of a pretty weighty pick up truck would have given the driver a better chance of bringing the RV to a controlled stop.
So, inspect your tyres regularly and if you do tow stuff, bear it in mind when you press the pedal on the right :)
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
In the video you can see its the front R/H tyre that explodes. Prior to the blow out it does not appear to be under inflated. Would TPMS help? Perhaps it might register a higher temperature but it could be just one of those things.
The problem is that the driver lost control.
If the (steering) wheel has a sudden and forceful movement you need to take control quickly. The driver might have had only one hand on the wheel or worse still could have been using one of those knobs that should only be used on forklift trucks.
Regardless of using tyre pressure monitors or not you need to know how to control your vehicle if you have a blow out... Take ten minutes to watch this video
