NIC S
Will the wind up type arial work with a digital signal,if not can it be modified or would it need replacing.I'm not sure of the make its has a small winding handle inside with a outer ring with pointer to rotate,on the outside it has two alloy box sections as supports and the top bit is white with two flat plates,A rubbish desription but I hope someone can identify from this,Cheers
