Tv Reception
Discussion in 'The Beginner' started by karel, Apr 28, 2014.
  1. karel
    karel Read Only Funster
    Apr 12, 2014
    34
    18
    huddersfield
    Hi, Probably going to bore the pants off you with questions as total newbie so here's the latest.
    Just bought a avtex T.V that are designed for campervan use (So it says on the box :Smile:) I have a converted van and will be fitting it to the inside of one of the panels. Total newbie question, but what is the best way/options to get a good reception?
    Would this be the best bet to compliment the brand ? http://www.ebay.co.uk/itm/Avtex-STH...ervan_Caravan_Accessories&hash=item1c3efce5c1
    cheers
    • Like it Like it x 1
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,454
    6,446
    St. Helens MERSEYSIDE
    tv
    Hi Karel I have just bought one too and I bought the new model aerial It picked up over 180 channels whilst temporarily stuck to my window on the inside :Smile: so I can recommend it the model is (sth 2000)
  3. karel
    Apr 12, 2014
    34
    18
    huddersfield
    Cheers that's the one in the link will purchase now :thumb:
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    as its a direction aerial you may have mounting problems.......
    Digital tv signals are very narrow and you need to point it directly towards the local transmitter mast or the picture will pixelate and lock.....if you get a picture at all.....so mounting in the correct direction is critical.
    Dont forget, EVERY time you move to another area you MUST retune the tv to the local frequencies.
    The advantage with a sat dish is once tuned, the frequencies are the same no matter where you are in the uk so no further tuning required....you only need point at the satellite.
  5. Bellini
    Bellini Funster
    Sep 3, 2013
    761
    799
    Crowthorne, Berkshire
    This sounds very promising. :thumb:
    If my Mobisat aerial doesn't get me any channels on its next outing, then I'm getting the Avtex one.
  6. karel
    Apr 12, 2014
    34
    18
    huddersfield
    Did not know this, have you suggestions for a Sat dish?
  7. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    not a problem but inconvenient and time consuming finding the local transmitter to get the signal to tune to.
    A tv signal finder will help.
    Sat dish....i use a sky mini dish (around 40cm i think) mounted to an old camera tripod.....works for me and cost less than £20 (around £30 now) as i already had the tripod.
    You can just see the dish at the front of the RV in the pic.
    [​IMG]
  8. Dogeared
    Dogeared Funster Life Member
    Jan 16, 2013
    258
    244
    Blackburn
    Hi have had a number of aerials over the years both for motorhome and caravan, all have been quite variable in quality. Best we have ever had is our current one.
    NEW Avtex, high gain, omni-directional aerial with FM, AM, MW & LW, receives Digital and analogue signal
    Not sure what they cost, but have used it in the lakes and down south, and in most places have had brilliant reception
  9. karel
    Apr 12, 2014
    34
    18
    huddersfield
  10. martin1485
    martin1485 Funster
    Jan 26, 2010
    446
    669
    Conwy, North Wales
  11. WillH
    WillH Funster
    Feb 9, 2008
    1,794
    1,498
    SW Scotland
    Easiest way to find out which way to point the aerial is to look at the other vans our houses around you.
    Rgds
    Bill
  12. buckby
    buckby Read Only Funster
    Sep 6, 2013
    213
    148
    nottinghamshire
    The new milenco Omni directional aerial is getting really good reviews
  13. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    6,053
    9,365
    Wrenthorpe, Wakefield.
    We have the same tv and arial . They work brilliantly. Stuck to either side of the motorhomes window . Bought this year, with intentions of using it in the PVC when we get it. True you do have to retune if you move to a different area. But it's just a case of pressing the red button. It's a lot easier than the old tv we had.
    But we've also got a multi mo satellite dish. Just incase. :thumb:
  14. Wombles
    Wombles Funster
    Oct 28, 2013
    2,722
    1,926
    SW England
    Avtex aerial is great - easy to use & excellent reception :BigGrin:
  15. karel
    Apr 12, 2014
    34
    18
    huddersfield
    Brilliant choice and after my first trip it worked perfect, v good picture
  16. Wombles
    Wombles Funster
    Oct 28, 2013
    2,722
    1,926
    SW England
    Great to know it worked well for you - love it when Funster knowledge/experience (good & bad!) helps each other :thumb:
