tv power
Discussion in 'Tech/Mech General' started by niggle, Mar 21, 2011.
  1. niggle
    niggle Banned - Rule 1
    Aug 5, 2010
    806
    607
    SOUTH AND FRANCE
    im looking for a way of only allowing 12 volt to the tv from the lesure batts amps dont matter as long as its above 80 ta :BigGrin:
  2. steles
    steles Read Only Funster
    Sep 2, 2007
    240
    61
    Kent
    More details required.
  3. laneside
    laneside Funster
    Aug 14, 2009
    3,542
    5,502
    Oradour sur Vayres
    If you mean 80 amp then i think you need a rain check:cry::cry:
  4. steles
    Sep 2, 2007
    240
    61
    Kent
    Lack of response guess you have sorted for yourself
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi niggle,not sure what you mean but our tv is wired direct into the Ariel 12v socket :thumb::Wink:
    terry
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    if I am reading your post correctly you want to limit the voltage to 12v rather than whatever the battery level is so you can protect the TV circuitry. That being the case you need a 12v Regulator, not 80 amps but probably 80Watts, Maplins sell one to suit. Go and discuss your requirements with them.
    If the above is not what you were looking for then please explain your requirements in a little extra detail. Personally I use a small (150W) inverter and run the TV on 240V, everything is protected then.
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    see att
    terry
  8. niggle
    Aug 5, 2010
    806
    607
    SOUTH AND FRANCE
    :Rofl1: sorry if i was a bit short on the post,,,,i have new pilot m/h,:BigGrin: but no lead for the tv,pilot put in the tv cubard put a 12 volt cigaret plug,but they are prone to power spike,so i need a regulator to stop this ?? the tv runs on 12 volt and takes 49 watts running and 0.7on stand by but the top end tollerance is 13 volts . :Rofl1::Rofl1: i got my watts and amps mixed up sorrry.i know muplins sell a kit but its got all kinds of stuff i dont need with it all i need is some thing to stop the power spiking above 12 volts nigel :thumb:
  9. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,133
    13,880
    Heavan
    so you want to rig a battery direct to the 12v tv? yeah? so the battery only runs the TV yeah?
    personally I would ignore the talk of a power spike and take my chance. Never had a problem in all my caravan/motorhome days of a TV being blown up by a power spike from 12v
  10. GuitarDave
    GuitarDave Read Only Funster
    Apr 20, 2010
    17
    Kent
    The tv will regulate the voltage itself. All 12v tvs are designed to do this, I've been running mine in the van for 3years with no problems.:thumb:
