TV power supply
Discussion in 'TV & Satellite' started by DM23, Sep 21, 2016.
  1. DM23
    DM23 Funster
    May 29, 2016
    106
    72
    Hampshire
    Hi all, I'm still pretty new to 12v so I'd like to double check something with you please.
    We were always intending buying a proper 12v TV/DVD eventually (so we can use it off hook up) but until then we've been using an old TV/DVD we already had laying around the house. Unfortunately the DVD part gave up on us whilst we were away on hols so we had to go out and buy a replacement locally. A bit annoying but I remember reading on here that most modern TVs are 12v anyway so I wasn't too bothered as we should be able to just replace the power supply with a cigarette lighter one.
    I've just bought one of these:
    Now it has arrived, I can see that on the back of the power supply it says output 12.6V 5.6A.
    The TV's own power supply says output 12V 3A
    I just want to check my understanding is correct: so long as the voltages match, the different amperages don't matter because they only indicate how much current it is capable of delivering and the TV will still only draw 3A. Correct?
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,541
    7,821
    I just means you have a higher rated power supply, which is good..
    the TV will draw 3 amps but the supply is capable of doing more.. So no problems..
    Better than having a supply that is right on its limit. They no doubt use that same supply for several different models..
    • Thanks Thanks x 1
  3. DM23
    DM23 Funster
    May 29, 2016
    106
    72
    Hampshire
    Thanks for confirming what I was thinking......didn't want to blow up the TV lol
    Septembers already been a bad (expensive) month....didn't want to add the new TV to the list of things needing fixing or replacing!
  4. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    Just make sure it's the right connector and, more importantly, that the polarity is correct.
  5. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    1,796
    4,618
    Langtoft, South Lincs
    ...and that your batteries have enough capacity for the amount of viewing you want to do ;).
  6. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,136
    3,686
    Scotland
    12v TV/DvD might not be as expensive as you think. They also plug straight into the cigar type socket with no need for stabilisers. Spending £24 is a wasre of money if you are going to buy a tv soon.
    Also most tvs are not 12 v compatible.
  7. DM23
    DM23 Funster
    May 29, 2016
    106
    72
    Hampshire
    Yep the connector is the right one, but good point about the polarity. The original adaptor is showing the centre is positive, I can't find a similar symbol on the new adaptor so I've sent an enquiry to the seller.
    We've got one 110ah battery at the moment and intending to get another one when funds allow. The most we've done off-grid so far is 2 nights and the battery hardly dropped at all. Will keep an eye on it though ;-)
    We already have the TV - ours broke whilst we were on hols and as we couldn't find an accessory shop we ended up with a Schneider LED TV/DVD combo from Conforama which we used via the mains socket whilst we were on hook up. But as the power supply output is 12v its just a case of replacing the power supply with a cigarette lighter one - I went for the stabiliser as I've read there can be problem watching DVDs if the voltage fluctuates.
    • Like Like x 2
  8. The Wino
    The Wino Funster
    Mar 23, 2012
    1,185
    2,188
    leicester
    As the other reply said you were lucky I went through loads at currys most now 15 or 17v .
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,892
    17,556
    YO11 2BD
    Compatable with what ?
    Far more smaller tv's, up to maybe 24", are 12v via a transformer than are true 230v.
    12v is 12v whether it comes from a power supply or a battery.
  10. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,010
    6,036
    West Sussex
    If you are only doing a couple of nights you will be fine, the newer TV's with LED back lighting draw a lot less current ours only takes 1.5 amps our stereo unit which I route the TV sound through uses 2 amps!
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,067
    2,916
    Kendal, Cumbria
    That's nearly true but it depends on how fussy the TV is. A motorhome "12v" socket almost never supplies 12v and varies from 12 - 14.5v. A stabilising device holds its output at 12v. Having said that all three of the TVs I've had over the years have survived perfectly well connected directly to the van supply.
Similar Threads
  1. Madmag
    294
  2. irnbru
    4
    262
  3. Snowbird
    23
    647
  4. 955matt
    10
    413
  5. gus-lopez
    8
    704
