TV Mount through a shower wall
Discussion in 'The Beginner' started by themountaintiger, Jun 6, 2010.
  1. themountaintiger
    themountaintiger Read Only Funster
    Sep 27, 2009
    355
    63
    Lancashire
    Is it ok to mount a tv wall bracket, to an internal wall, the reverse of which would be a shower wall?? I have a swift sundance 630G
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,940
    17,606
    YO11 2BD
    difficult to make it neat unless theres a cupboard in the shower room.
    the bracket fixings will need to go right through the wall with large washers or a spreader plate in the shower room.
    otherwiae, as long as the fixings are sealed, there is no reason why not.
  3. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,801
    39,302
    Bit dodgey that,, most internall walls are made of covered thin plywood set on a thin wood frame work and hollow,,and not the same as outer walls which are sandwich construction and can take a bit of weight "With Care"
    If you intend to remove the tv from the bracket whilst travelling, it should be ok.. but with the tv in place there will be a certain amount of bounce which in turn will place a lot of stress on the wall even as Papajohn says with a back plate..
    Once upon a time I wanted to do the same in a caravan,, same problem thin walls,, so what I did was drill a half inch hole where the bracket was to go and get some expanding foam from B&Q and squirt some in using the flexi tube to get as much in around and past the little hole as possible,, leave to cure for a day,, and you have a more or less solid wall.. :thumb:
  4. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    I too have a 630g and I would not do it on the ground that if the backing plate on the shower side leaks the damage could be serious and the cost eye watering.
    On the other hand why do you want to fit it on in that position? Its puts the TV at the head of the bed, the other side of the entrance is a much better position and as you can mount it through the wardrobe its easier and more comfortable to watch.
    I made my own mounting arm and the backing plates where of stainless steal 8" X 3" both sides of the bulkhead the arm is such that the TV can be viewed from the bed and swung around to be watched from the rest on the accommodation, I also made a small ledge for the TV to on and secured by a lip that the TV sits in to stop it moving during travel.
    If you want some photo's let me know.
    Doug...
  5. pappajohn
    Aug 26, 2007
    29,940
    17,606
    YO11 2BD
    the internal walls on swifts are around 3/8th's solid fibre board and as long as there is some sort of spreader they are strong enough.
    my 15" lcd/dvd is permenently mounted on the wardrobe/cupboard wall in the same manner and doesnt move.
    i have a 6" X 6" X 1/8th spreader plate in the cupboard.:thumb:
  6. old-mo
    Oct 16, 2008
    12,801
    39,302
    You live and learn,, did not realise that John,, mind i`m going back 20 years. :Doh:
  7. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Thanks for replies
    Ill have a think, currently it lives in its box and i just unpack , stand up and plug in. true not the instant tv access I would like but the additional 3 mins setting up and packing away wont kill me... 19" Telly weighs in at 7kg so not sure to what extent the spreader plate will cope...An option would be to get a smaller tv but it already took some convincing of the misses that I couldnt run our 46" LCD from the leisure batteries so she could watch Coronation Street!!
  8. pappajohn
    Aug 26, 2007
    29,940
    17,606
    YO11 2BD
    i think my 15" lcd/dvd weighs around 5kg:thumb:
  9. pappajohn
    Aug 26, 2007
    29,940
    17,606
    YO11 2BD
    other makes may be different construction Mo....:Doh:
