TV interference
Discussion in 'Motorhome Chat' started by Melvin, Mar 16, 2016.
  1. Melvin
    Melvin Funster
    Jan 22, 2016
    138
    120
    Norfolk
    Im using my TV for the first time in my new MH but every time the water is run the TV goes blank .Had a Aerial fitted by the dealer before I bought the van ; have they connected it incorrectly or is there something that I can do to solve this. The Aerial is a Status I believe and there is a little box of tricks labelled Vision Plus digital amplifier in the cupboard below .Any feedback would be most appreciated . Thanks (n)
  2. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    There should be a light on the amplifier, does it go out when you turn on the tap?
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,961
    12,252
    Plympton, Devon
    Sounds like an interference problem. Fitting a capacitor across the pump terminals might cure it. Cost should be very low but I suggest contacting the dealer first.
  4. chaser
    chaser Funster
    Feb 16, 2013
    7,716
    8,790
    uttoxeter
    I would say you are low on battery power, every time you use the pump, not enough electric to keep the TV on.
    • Like it Like it x 5
  5. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,161
    3,963
    Scotland
    The vision plus box is a signal finder.....when you switch it on you will notice a red light.........if you rotate the aerial to the best signal available it should go to amber then green.
    Each time you move you will have to retune the tv unless you are in the same area.
    Your problem with the tv going blank may well be your battery power is very low and the tv is not getting enough when the pump runs.
  6. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,252
    3,498
    Rural South West Wales.
    Run the T.V. from mains power if you can & see if there's a difference
    • Like it Like it x 1
    • Informative Informative x 1
  7. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,252
    3,498
    Connecting the T.V. to mains power will / should eradicate any battery power issues too & eliminate that potential cause.
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    I agree with low battery power.
    The tv will have a minimum working voltage and starting the pump may be enough to drop the voltage below the minimum required.
    Your battery may just need charging, or could be past its best and not accepting a full charge.
    If you have a voltmeter connect it across the battery and check the voltage, turn on the tv and note the battery voltage then start the pump and check the voltage with the pump running.
    If it drops considerably the battery may be kaput....or needs a proper charge then test again.
  9. Melvin
    Melvin Funster
    Jan 22, 2016
    138
    120
    Norfolk
    Thanks for the replies ,I'm running on mains as my TV is not 12v, the Batt should be OK as it should be new as is the van. The vision plus box light is on red as that is all Iget in any position that I move the aerial .I will have to speak to the dealer when I get home about this and also I have just realised that I don't have any instructions for the extras that they fitted, which I assume I should have . Once again thanks to all .
  10. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,161
    3,963
    Scotland
    Melvin, there is a little dial in the right hand side of the vision plus box......you can turn it clockwise to boost your signal........failing that you might have to put the aerial in the vertical (red) on the pole that goes through the roof. By turning the handle at the bottom.
    Your signal booster will be running on 12v also, so the problem might still manifest itself through your 12v system.
    Nothing worse when you cannot tune in.......even though there is never nothing on.
  11. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,252
    3,498
    The first time we used our Avtex T.V. in Llandovery 3 weeks ago the signal finder / amplifier would not turn amber or green & was on red but to our surprise we had a reasonable enough signal to pick up most channels - why this is I don't know as i'm not an expert - just saying our experience.
  12. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,714
    2,185
    Scotland
    @Melvin
    Might not be the exact model fitted but may be of some assistance?
    I've got the manual for the 530 as well but too large to upload. Could e-mail to you if of any use.
