TV bracket - how to fix it up?
Discussion in 'Tech/Mech General' started by RichardB, Apr 11, 2015.
  1. RichardB
    RichardB Funster
    Oct 19, 2013
    216
    109
    East Yorkshire
    Hi all
    I have just bought a Avtex Svenson SV9 double arm TV bracket.
    I want to put it on the side of the wardrobe in my van.
    Photo shows the same bracket in the same position I want, on the same van:
    [​IMG]
    I am not sure how I need to mount it - I am thinking of using some bolts but not sure what what I need to put at the back to make it strong enough.
    Would welcome any advise and any pictures of how others have mounted their brackets, what size bolts etc.
    Richard
  2. hilldweller
    Dec 5, 2008
    27,771
    26,860
    Macclesfield
    I put a full width piece of 12mm ply inside the wardrobe but because the wall is just two thin pieces of ply had to make metal spacers so the bolts did not crush the wall flat.
  3. RichardB
    RichardB Funster
    Oct 19, 2013
    216
    109
    East Yorkshire
    The wall is a piece solid wood (well mdf or something similar) as I have already had to drill a hole in it for something else.
    If i put a piece of 12mm ply behind where the bracket goes and bolt through would that do it?
  4. hilldweller
    Dec 5, 2008
    27,771
    26,860
    Macclesfield
    No idea now. My wall is solid only at the edges and a bit in the middle so I put a full width piece of ply across bridging the three bits of solid wood.
    You are going to have to make you own mind up. You may have drilled through just where there was a batten inside, but I don't know. Weight is everything in a MH so really it should not be solid wood.
  5. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,193
    Rutland
    Some may say Worst ways up it would be Mdf so a couple of bolts and large washers should do !
    Cautious ones would put an oversized plate inside the wardrobe to spread the load.
    Others like myself would clamp it to the table whilst driving ( if the passengers want to watch it ) ,if it's not needed whilst travelling why drill holes in your pride and joy for no reason, ?
    Vlad
  6. Viennese
    Viennese Funster
    May 21, 2008
    2,484
    2,707
    Oxford
    I was advised to use M6 bolts and large washers to put a bracket in a similar situation...
  7. Allan & Loren
    Allan & Loren Funster
    Dec 8, 2014
    1,301
    1,929
    Leyland, Lancashire
    We've just spent most of the day putting up a similar bracket, setting up the TV/DVD/free view/satellite. Different location and we were lucky as it was solid timber we were screwing in to.
  8. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,605
    12,024
    E Yorks
    I did a similar thing with the one in our camper as I wanted to put it on the outside of the washroom wall above the side of the bed (we always slob out on the bed when watching TV on an evening!). In my 'collection' of bits and bobs fortunately I had some large pieces of flat metal, about 3 inches square with holes through the middle (think of a square washer!) which were perfect to use as spreader plates on the rear and I then just bolted through them - tighten them well, but not so much as you cause your furniture to be squished/dented - even a solid MDF panel will squish a bit if you over-tighten.
  9. vectian
    vectian Funster
    Sep 21, 2013
    153
    132
    Isle of Wight
    Decide where you want it and drill holes suitable for the bolts you're going to use.
    If its solid no probs just big washers at the back.
    If it's hollow use spacers eg large nuts or copper tube between the front and back and a large piece of ply on the back
  10. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Depends on the size/weight of your telly, I think. I just used 5 wood screws of the correct length, (3/4"). Never moved in nearly two years.
