TV Ariel - which one?
Discussion in 'The Beginner' started by June Beere, Oct 5, 2015.
  1. June Beere
    June Beere Read Only Funster
    Sep 30, 2015
    4
    Basingstoke
    We have used our motor home infrequently this year but do have problem with the Ariel that came as standard with the motor home in that it doesn't pick up much in the way of signal. I appreciate that to have a new one fitted is expensive and we do aim to travel overseas therefore if we are to fit a new one it would be good to go satellite - can anyone please give us some ideas of what is the best and why. We are not that technically minded and are a little blown away by some of the previous posts. We live in Basingstoke and it would be good to hook up with someone who is local that might be able to share their knowledge.
    June
  2. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,561
    3,004
    East london
    IT may well be worth establishing which arial you have .. if it's one that can be lifted up and turned and put in a horizontal or vertical position (http://www.worldofcamping.co.uk/vis...=030ea12bf129b9863498af9b2339c2e9&fo_s=gplauk) then you may want to get the free android app called UK Arial alignment ..
    If it's a different type then I'm not really sure how good they are as we've not had one of those for a long time I'm sure someone will advise you though.
    We used to have satellite. . But now we just use the Internet, downloaded files and use our on board blu ray player.
  3. parknride
    parknride Funster
    Jan 21, 2014
    2,112
    4,852
    cumbria
    Hi, welcome to Fun.
    Watching with interest as since we changed vans we are in same position.
  4. Manic
    Manic Funster
    Nov 4, 2011
    903
    1,049
    Uk
    I have a Avtex aerial which fits on the side of the van with a sucker and is very good, I use this when trees block the satellite signal. With all the changes with the Satellite beam changes and depending where you would be travelling in Europe, you should think carefully about buying a Satellite system. I've not been abroad since the changes but will be next year so will see(I have a KVH Tracvision dome)
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    • Like Like x 2
  6. June Beere
    Sep 30, 2015
    4
    Basingstoke
    Having looked at the specification online I think we have Avtex high gain, omni-directional aerial with FM, AM, MW & LW, receives Digital and analogue signal arieal
  7. ciderman
    ciderman Funster
    Jul 2, 2011
    359
    409
    derbyshire
    you really need directional for freeview tv as the signal is direction dependant so a status 530 is good along with a signal finder which you plug in to the Ariel turn it from inside the mh look for the green leds lock in place plug in tv and set to retune job done.
    • Like Like x 1
  8. June Beere
    Sep 30, 2015
    4
    Basingstoke
    Although I have detailed the aerial - all I know is it is like a stick on the roof - like I say, no technical knowledge at all :)
  9. ciderman
    ciderman Funster
    Jul 2, 2011
    359
    409
    derbyshire
  10. June Beere
    Sep 30, 2015
    4
    Basingstoke
    Thanks for this Ciderman - Obviously requires professional fitting - so will look locally for a supplier - thanks
  11. ciderman
    ciderman Funster
    Jul 2, 2011
    359
    409
    derbyshire
    signal meter.png and something like this
  12. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,868
    7,622
    Paignton, Devon.
  13. buckby
    buckby
    Sep 6, 2013
    213
    148
    nottinghamshire
    We had the directional aerial and I got fed up with messing about with it so I bought a milenco Omni directional aerial after reading good reviews.
    It has now been on a year and I don't find a need to put the satellite dish up anymore I always get over 100 channels on my avtex televisions personally I have been well impressed.
    • Like Like x 1
  14. Tea Bag
    Tea Bag Funster
    Nov 3, 2013
    1,200
    2,032
    Portugal
    Hi June Beere.
    Sounds like you have the "Avtex Bee Sting" Ariel. This is the third unit with one of these fitted,the first two were worse than useless. It is very dependant on good quality Co-ax and fitting,this is what let the first two down,this one on a PVC. is a revelation,off we go each trip,with a TV Pole and every intention of fitting a localy bought cheapy ariel .It has now worked faultlessly for over a year and a half,"Time to leave the pole and clamps behind ? " LOL.
    As regards the SAT dish for France etc. It would seem that the signal is hit and miss about two thirds of the way down France,from what i can gather.Knowing nothing about Sat TV,but asking questions,people are beavering about even as i type this,to get some sort of device on the market,so keep your money in your pocket for a while longer.
    A,"Plus" about the Bee Sting thingy, we are still under 3Mtrs,so sail through the Peage with our SANEF ? Tag...... Result
    Tea Bag
  15. RidersofRohan
    RidersofRohan Funster
    Oct 2, 2014
    139
    315
    West Yorkshire
    Problem with these forums etc is that everyone comes and says get what I've got cos I can't be wrong, and if I am I don't want anyone to be better than me.
    I have tried various types and if you are prepared to try to find the strongest signal I believe one that is "directional" works best. But the omni directional ones are easier as you dont have to point them, sometimes you are in a strong signal and anything works well. In a weak signal area sometimes nothing works but you increase your chances with one you point. If you get a signal tracker similar to above it gives you a chance of a signal. The other thing is aerials are bits of pointy metal, coat hangers even, so paying a lot of money doesn't guarrantee success there isn't much technology going on in them.
    We poke the co ax cable through the back doors and the aerial sticks on the back door, I connect the tracker thing and point the aerial around until its the best I can get then connect it up. Sometimes its great other times its do something else other than watch tv!!
    Dont spend a fortune one at £20 is just as good as £400. Someone who has spent £400 will be along to tell you otherwise, and they might be right cos I haven't got one of theirs but its a hell of a gamble as they won't promise you 100% coverage because you can go anywhere in your van.
    • Like Like x 1
  16. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    2,975
    7,160
    Market Harborough
    Hi Jean, you would have found out by now that to get the best out of this great site you need to become a full member, the annual subscription is only £15.00 and you will more than get that back in advise. Good luck in your search of the best ariel or you could do what a lot of us do and read, talk and forget about telly. (y)
  17. Skinflint
    Skinflint Read Only Funster
    Oct 8, 2015
    4
    Erskine
    If you google motorhome tv aerial you will find load of dicsussions about this, the general concenus seems to be that the majority of aerials supplied with the vans are pretty useless. The best/cheapest fix appears to buy a log aerial like this
    mount it on a pole and then find some way to fix to your van, I have seen some clamped to the bike rack, with the cable simply fed via a window. You still need to point these towards the transmitter for your location but they give a great signal.
    It also means its something else to tidy away before you move off.
    Having said all this I am still using the original.
