TV and aerial power (1 Viewer)
Dec 23, 2015
444
522
Audenshaw
Pilote Pacific P650GJ
Over 6000 miles between 3 March to 26 September 2017.
I've just purchased a Cello 12v tv and an Avtex STH3000 aerial. Does the aerial need a 12v power supply if not being used with an Avtex tv? We only have one 12v socket next to the tv bracket. If the aerial does need power, would it be possible to use a two-way 12v socket adapter?
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
On the avtex tv it's got a powered output to the aerial within the menu when using 230V, however when just using 12V it should have come with a powered amplifier and i use a double 12V socket adapter like you suggest
Check if the Cello has a powered output for the aerial within the menu
Minxy
32,646
66,530
E Yorks
Carthago Compactline
I think you'll need to do as you suggest and use a twin adaptor for your 12v socket to plug both the TV and aerial into as your Cello is extremely unlikely to be able to 'feed' power to the aerial on its own.
gerry mcg
1,650
2,573
Glasgow, Scotland
Globecar 600L Revn
since 2016
there is an option to turn on a 5v aerial power feed in the 19" Cello traveller IIRC TV menu - so you can power an avtex sth3000 aeriel. It's at the bottom of the Channel menu ;)
