Tv Aerial
Discussion in 'The Beginner' started by Babyell, Jul 14, 2015.
  1. Babyell
    Babyell
    Jun 23, 2015
    96
    30
    Manchester
    and at weekend we parked up, got a good signal all seemed fine until we had to move van slightly to get some water. went and parked back in the exact same spot and no signal!?
    someone said in a previous post that these are rubbish....
    we drover around the field which was empty apart from us and we eventually got a signal. went out for a walk, came back and no signal again. this happened several times, intermittent signal. is there a better aerial or internal aerial that would improve this. we have the booster thing inside the van and that was turned to full.
  2. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    They are poor but if in a high signal area even a poor one is OK.
    Loose connection ? The co-ax connectors are notorious. Two types, soldered and screwed. Check all of them. Probably 3 of them.
    Screwed, make sure the screw is tight and the braid/screen contacts the outer body.
    Soldered, so many are not soldered and tarnish and fail, again unscrew examine, if not soldered bend the inner so it rubs inside the contact or solder. Again make sure the braid is in good contact with the body.
    Make sure the red LED is on on the amplifier box under the aerial.
  3. Babyell
    Babyell
    Jun 23, 2015
    96
    30
    Manchester
    1212.jpg this is the box inside. I checked all the connections and they seemed secure. it seemed when we shut the cupboard door or banged something the signal went off or glitch, could it be the wire?
  4. Babyell
    Babyell
    Jun 23, 2015
    96
    30
    Manchester
    also what is the spare short wire for?
  5. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    Try wriggling all the wires, inc power and localised tapping. It may be a cracked joint internally. Spare wire, maybe a bedroom feed ?
  6. Manic
    Manic Funster
    Nov 4, 2011
    1,045
    1,179
    Uk
    Could the short aerial wire go to an outside aerial point.
  7. namwaldog
    namwaldog Funster
    Jan 2, 2015
    488
    799
    Cumbria
    On our amplifier box there is only room for one output connection but we have two output points so have to make sure that the output point we are using in the one that is connected, The one that isn't connected always has an upward curve like the short one in your image so (long shot), is the aerial point you are using the one that is connected?
  8. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    Buy a plug in splitter, should work.
    • Like it Like it x 1
  9. rosalan
    rosalan Funster
    Jul 12, 2013
    882
    760
    Beds
    At a well known dealers we bought an aerial like yours and went back when it did not work. The next aerial was the same and after 5 units we got a signal, just. They decided it was our TV so tried an Avtex which worked. We gave up and parked on their camping ground and got a perfect picture. The next day we returned to the dealers and got a good signal where I parked this time. I since learned, as did the dealer, that they have a dead spot for signals but just a few feet away; perfect picture. I now have a satellite dish which opens a whole new can of worms.
  10. ambulancekidd
    ambulancekidd Funster
    Sep 23, 2014
    655
    1,548
    Ayrshire Scotland
    Your aerial is massively outdated. I know that these aerials are still sold as being adequate for digital reception but the are omnidirectional & what you need is unidirectional. In other words you need an adjustable aerial like the newer Status items. Your problems are stemming from the old aerial.
    Hope this helps..Robert.
  11. Babyell
    Babyell
    Jun 23, 2015
    96
    30
    Manchester
    Thanks everyone. Can anyone put a link to a decent aerial. Also would it effect the roof changing aerial by leaving opened screw holes?
  12. Neilfg
    Neilfg Funster
    Apr 9, 2014
    534
    533
    Bucks
    We use the Avtex STH3000, so far very good, better than our previous Vision Status.
  13. ambulancekidd
    Sep 23, 2014
    655
    1,548
    Ayrshire Scotland
    Teleco Teleplus X2 /39U TV Aerial is the one I have currently. The last two Status aerials that I've had developed leaks & had to be replaced. This one picks up a signal where the Status failed so its a win win situation.
    Read the Teleco Teleplus Aerial Review
    Robert.
  14. Manic
    Manic Funster
    Nov 4, 2011
    1,045
    1,179
    Uk
    We use the Avtex aerial and they work well. If you remove the Status aerial you already have you can buy a plate that uses the same holes to blank it of.
    • Like it Like it x 2
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,087
    17,751
    YO11 2BD
    [​IMG]
    No contest.....coathanger every time
  16. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,217
    2,021
    Cannock Staffordshire
    We had the same aerial fitted to our PVC and even though it picked up decent signal most of the time there were areas where it picked nothing up at all, on our latest van we have a Status 550 and we tested it out today in a area where we normally got nothing with the previous one - the difference was about 130 channels, absolutley stunning for the sake of about £40
  17. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    Got both, replaced the broken status on the roof, that works well most of the time, and have the status on a pole as a backup, but don't enjoy rigging it up in the rain on a cold dark winters evening so it mainly stays tucked away,
    Went to drive out of Kelvedon Hatch C&CC site once with the pole version still attached, luckily it clipped a tree which knocked it off, as it is mounted on brackets attached by d/s tape only my pride suffered any lasting damage. :getmecoat: :rofl::rofl::rofl: :rofl:
    Hymie
    • Funny Funny x 1
  18. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,778
    6,045
    Mansfield,Notts
    Status 550 as above Long Or Short mast A bit expensive but 100% reliable Never heard or read a bad word yet
    Apart from Yorkshire men and Scotts comments on price compared to Johns Coat hanger, but he's another story;)
  19. Tweedie
    Tweedie Funster
    Sep 14, 2015
    193
    140
    Northants
    Avtex STH3000 Aerial for us as well, excellent when used both inside and outside the van, does not need to be permanently fitted, very cost effective. Saving for a really good sat system at some time in the future till then the Avtex is really good for UK use. Will be interesting to see how it performs in France, suspect it will give us plenty of opportunity to practice our French. :)
  20. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,748
    2,683
    Tunbridge Wells
    Status directional aerial for us too. Had on the last van and got one fitted by the dealer in my new van.
