TV aerial advice please
Discussion in 'The Beginner' started by JimboT, Nov 18, 2013.
  1. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    this is a picture of the setup we have got
    [​IMG]
    [​IMG]
    [​IMG]
    we bought the van 2nd hand and it looks like at some point there was another box in booster cupboard.
    We don't get a good signal not sure if the aerial on roof can be raised.
    Any help advice needed.
    Plays dvd well!
    thanks
    Jim
  2. SandJ
    SandJ Read Only Funster
    Sep 14, 2007
    1,558
    518
    North Yorks
    Is the booster turned on? Follow the cable on left make sure the fuse has not gone. Do not know that booster but ones I do know light up.
    Have you got tv to digital?
    Is there digital in that area?
  3. Timetraveller
    Timetraveller Funster
    Nov 8, 2010
    178
    87
    Charente, France
    Don't want to state the obvious but been in your predicament myself :Doh:
    is the coax connected to tv and is vision box switched on? Don't think you can raise your antenna.
  4. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    booster light on digital signal in area will take cover off and look for fuse.
    I do know we had to change our aerial on house when we went digital a few years ago so wondering if the newer booster was removed at some point.
    Jim
  5. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    all connection correct just not a strong enough signal.
    Jim
  6. SandJ
    Sep 14, 2007
    1,558
    518
    North Yorks
  7. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    Are you sure you have the tv on the DTV setting, as most places now have no analogue signal, I can only see TV on the bar under where it say's channel 4
    You also need to retune the tv at each area you visit and it might be worth checking that the aerial is man enough to receive digital signals,( if yours is a status 330 it is) not sure about earlier models.
  8. DeuceBG
    DeuceBG Funster
    Oct 28, 2013
    486
    432
    Lincoln
    Never had much luck with those "Dinner Plates" so we bought a conventional aerial and it works OK, depending upon the area.
    Some place just don't let the digital signal through at all.
    It's not like analogue where you can watch snow and listen to fizzing if you want to, with digital it's all or nothing....:cry:
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    status 315 are about as useless as you can get.
    its an omnidirectional aerial, meaning it receives a signal from any direction so cant be as efficient as a directional aerial and will never get a decent signal if you cant see the transmitter mast.
    my advise is bin it and buy a decent directional aerial.
    • Like Like x 3
  10. BwB
    BwB Funster Life Member
    Apr 3, 2011
    606
    563
    Brandon Suffolk UK
    I'm probably stating the obvious, but you've run the re-tune menu on the TV for the digital tuner (not the old analogue tuner)? I have to do ours every time we visit a new camp site. When it's doing a search for new channels it gives a percentage readout of signal power and quality - anything more than 80% seems ok.
    The rest of your setup looks ok, if the cable from the Vision Plus to the TV is plugged in the back of the TV ok and you've screwed the booster wheel all the way up (and then back a quarter of a turn (works best on ours)) then you've done most of what I would have done. Those flying saucer type Ariels are not the best but are normally good enough.
    Sorry I can't suggest more things to try.:Sad:
  11. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    check with house aerial so must be van aerial not up to the job most likely ok with old analog signal.
    whats best to get?
    jim
  12. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,246
    East Sussex 01-580-881288
  13. bailey
    bailey
    Jan 18, 2010
    541
    138
    Airdrie Scotland
    It will be a struggle to pick up digital with that omi dir Ariel
  14. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,401
    2,447
    Tunbridge Wells
    I agree with that. I had one of those about 15 years or so ago on my caravan and it was pretty useless even then on analogue. I now have directional one (Status) and the extension pole is in the wardrobe so I can lift it up about 3 or 4ft. I must say that I have been very impressed with it so far, but have not been into the mountains yet! But, as others have said, you have to tune in your TV every time you stop.
  15. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    looks like i will have to invest a bit !
    jim
  16. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    Have had no signal went to Waldergraves this weekend and guess what had a good signal all weekend.
    Did pop into John Cross last Sunday very helpful and they said unless you have clear line to main aerial you will struggle, also had a look at a few options to upgrade.
    Jim
  17. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    With those Status flying saucer omni directional antennas, you have to be very close to a transmitter to get a signal otherwise they are next to useless, other than as a substitute Frisbee.....
  18. flyboyprowler
    flyboyprowler Read Only Funster
    Aug 29, 2013
    58
    12
    West Sussex and Spain
    I am with you Jim, new to the game, and our new toy has a self seek dish but won't lock on to the satellite. Apparently the tuner box needs to be upgraded, so that is being done at the moment. Here in Spain it cost € 75.00 but hopefully will be ok after. Best of luck with your solution.
    Ainsley
  19. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,366
    9,811
    even with the update, you may struggle to get uk tv in spain on your satellite box as the footprint of coverage changed when they moved the satellites. some places it will get some channels others it may get none now
    no problem if your going for the euro satellites though
  20. stcyr
    stcyr Funster
    Apr 11, 2011
    1,673
    1,109
    Normandie
    We've found the best aerial is the Avtex figure-8 one.
    Usually it's just plonked on the roof through the skylight. Sometimes it's left suckered to the rear end of the roof - occasionally just on the window...
    We also use it in the house. Never failed us yet :Smile:
    • Like Like x 1
