tv 240/12volt help unsure
Discussion in 'The Beginner' started by jgee, Jan 23, 2010.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    i have a 240volt tv lcd television but the lead to the tv goes throug a box converting it to 12volts how do i use tv in moterhome when not on 240 volts hook up to run on 12volts is there some sort of adapter or do i need to buy a tv dedicated for moterhomes:Sad:
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    hi jgee,
    you can run the tv direct from the 12v system but if the voltage is too high....just off charge or connected to hookup...then damage CAN occure.
    you can buy a voltage stabilizer unit which designed for tv's and is regulated to 12v.
    AMPEROR
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,258
    5,239
    East Sussex 01-580-881288
    The Oracle has yet again risen to the occasion:thumb:
    Peter
  4. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    89
    Plymouth
    Click on FORUMS at the top off the page and scroll down to TV & satellites All the info you need is there Just need to browse the site!!:thumb:
  5. M&L
    M&L Read Only Funster
    Jan 26, 2008
    75
    North Lincolnshire
    The easiest way is to use a 150 watt inverter plugged into the 12v socket, my tv in the van is 240v only so I do this anyway.
    To plug it straight into the 12v socket means that you will have to cut the cable and put a 12v plug onto the end, this will invalidate the warranty if it is new. This did happen to me last year when a tv was only 6 months old, I sent it back but they were not happy that the cable had been messed about with.
    Mike
  6. jgee
    Dec 21, 2009
    85
    wigan
    tv12volt 240volt unsure
    the lead to my tv is 240 to 12volts via black box and into jack plug on tv using 12volt socket in moterhome is there a custom made lead i could use to then use 12volts:Sad:
  7. pappajohn
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    i doubt it but very easy to make one up.
    just determine if the positive is either the inside or the outside of the plug. usually its the inside.
    personally id use a stabilizer but its your choice.
