turbo woes maybe
Discussion in 'Motorhome Chat' started by tofo, Mar 4, 2013.
  1. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,427
    Kirby cross further from londin
    my R reg fiat ducato 1.9 td 1998
    first it passed its mot today
    going to the test i noticed a whooshing noise
    like an air leak on inlet manifold but nothing apparent
    test passed thought no more till coming home
    seemed a little slugish hill i would go up in forth
    was a struggle in third
    when the engine failed in 2009
    the coolant run through the exhaust
    to the road
    i was warned that will shorten the life of the turbo
    which is what i think has happened
    should i use a rebuild kit like or similar to this
    http://item.mobileweb.ebay.co.uk/viewitem?itemId=121046584428&cmd=VIDESC
    or obtain an exchange turbo
    if we all think the turbo has failed
    thanks in advance for your replies
    :thumb::thumb::thumb:​
  2. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    With a air rushing whoosing sound --have you checked the air pipes in and out of the intercooler ect?
    Sounds like it`s creating pressure but you have a leaky air pipe.
    Turbos usually whine and smoke (like a annoyed woman) when they give up .
    • Like Like x 2
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,753
    6,251
    South yorks
    I also would check the pipes for leaks/splits -No idea on the kit (got to be worth a try :Wink:) new turbo's can run into 500 quid or so :Eeek:
    terry
    • Like Like x 1
  4. highwayman
    highwayman Funster Life Member
    Jul 31, 2007
    858
    476
    Kent coast
    We had the same problem, turbo hose had come off under the top radiator hose.
    I couldn't see it from the front of the vehicle but Sheree spotted it from the side.
    Cheers. Nige
    • Like Like x 1
  5. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,427
    Well done sheree correct answer
    Just had a look at the said pipe it was off
    the plastic cable tie gone
    I am assuming that to be the fault
    As there is no smoke at the exhaust
    Only black puffs when reving it and allowing
    it to return to rest
    hose now returned to correct position
    Unable to test run at the moment
    as I hadn't driven it for a while
    It may just of seemed sluggish
    And the extra noise from the intake
    Had me looking for fault
    But your write you dont notice that hose
    Till your pointed towards it
    strange noise though and makes you think
    Oohhherrr that sounds expensive
    Probably me ferreting under the bonnet checking before its test
    Only one advise puncture in drive shaft gaiter
    He said a puncture patch would do it
    But a replacement would be better
    Not sure wether to try a glue on one
    Don't fancy taking the drive shaft out
    Well thanks folks for your replies
    With a bit of luck job done
    Miss Sheree and nige :clap::clap::thanks::thanks::thanks:​
