Turbo boost pressure (1 Viewer)
bartiny
284
404
Accrington, Lancashire
Since 2008
Hi,
Does anybody know what the correct boost pressure should be on a 1996 Peugeot boxer 2.5 td Please.
I have looked on google and I have found 1 answer of 1 Bar, does this sound about right?
I had a seized waste gate and the actuator rod was bent, so all freed off now and the rod straightened, just wondered what to set it at.
Thanks (y)
andy63
4,672
15,017
south shields
None
since 1990
Hi,
Thanks (y)
Typical boost pressure could vary from 5/6 psi up to 15 depending on engine speed and load..
That figure could rise to nearer 28psi max boost on a tuned/mapped engine I think..
I think my max pressure on a Ford 2.4 tdci is in the region of 1.4 bar but it's a while since I played about with the torque app which displays the boost pressure as you drive..
Ta andy
43,329
49,444
Ta andy
Dont forget though....this is an old school, mechanical injection engine...not a modern common rail computer controlled jobby.
bartiny
bartiny
284
404
Since 2008
Ta andy
Cheers Andy, I think my set up is a bit more basic than yours, its a mechanical diaphragm that works off the pressure build up in the turbo, once set, thats it, the waste gate starts to open at the set pressure, so I assume that the pressure does not go above the preset pressure :unsure: But not 100% on that.
(y)
andy63
4,672
15,017
south shields
None
since 1990
(y)
Yea think I get it.. :) you need to set a max boost pressure ie the pressure your waste gate opens at..
My old tranny wasn't turbo and present one has a variable vane set up which is what @pappajohn was reminding me of....well hope you get there.
Ta andy
bartiny
bartiny
284
404
Since 2008
I have set it at 15 psi, took it for a run round 10 mls, All seems ok, just wondered if a couple of psi either way would make much difference?
andy63
4,672
15,017
south shields
None
since 1990
If she is running well with no excess smoke then don't see any benefit in increasing it unless you alter the fuelling as well..
Hope that's a result ..and mot emissions are okay. ..but it sounds like it's easily altered.
Ta Andy.
bartiny
bartiny
284
404
Since 2008
Ta Andy.
Yep easily altered, lock nut threaded bar, just a PITA to get to:LOL:(y)
