Tunnel weight limit
Discussion in 'Motorhome Chat' started by sally47, Nov 21, 2015.
  1. sally47
    sally47 Funster
    Apr 29, 2014
    169
    61
    Been checking ferry prices and would like to go via tunnel now the question I have for you all is ...height of van 3m ok length 8.5m ok weight 4.5t not ok seems they take up to 18m but only 3.5 t has anyone got a 3.5 t 18 m van surely that's not possible so do I have to go on the ferry
    • Like Like x 1
  2. ivorantony
    ivorantony Funster
    Jan 22, 2013
    490
    514
    London SE
    as you see full size coaches on the same train I cannot see a problem!
    we are 3.9 tonne and never had a problem,
  3. Speve
    Speve Funster
    Jul 29, 2013
    2,040
    1,761
    Salisbury
    We've never had a problem now booked with 4250kg plus 1700kg trailer.
  4. icantremember
    icantremember Funster
    Sep 2, 2010
    5,222
    7,314
    Nr Watton in Norfolk
    For the tunnel motorhome weight makes no difference .... just make sure you book as a motorhome.
  5. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,513
    2,086
    Scotland
    Are you looking at a van as opposed to a motorhome option?
  6. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    5,829
    10,760
    East Sussex
    I think they call them camping car or something similar - weight isn't an issue
  7. G T and Dottie
    G T and Dottie Funster
    Jan 31, 2015
    272
    277
    Gloucester
    18 m is the normal max length of a standard articulated lorry 41 ton weight limit ( in Europe, 44 ton in GB). Confusion somewhere me thinks.
  8. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,188
    876
    Isle of Sheppy
    Make sure you book as a "campervan" - makes no difference what weight/length/height you are. We are also 4.5 tonne and 3.1 m high and always use the tunnel.
    Denise
  9. TerryL
    TerryL Funster
    Mar 5, 2010
    1,355
    1,333
    North East
    In the dropdown box for vehicle type select "campervan". You will travel in the single deck carriages along with coaches and cars with roof boxes.
    You're not the first by any means - it's not very clear on their webpage.
  10. ceejayt
    ceejayt Funster Life Member
    Aug 12, 2015
    403
    514
    York
    Slightly off topic but tunnel related. We have used the tunnel lots of times. My question relates to gas as we have 60 litre under slung tank. I have a series of knobs inside the van which shut off the gas to each appliance. To turn off the tank 'at source' is difficult to get at to say the least. Do people think turning off inside the van is sufficient or it should be turned off at source?
  11. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,562
    3,020
    East london
    It should be shut off at source and they may want to check
  12. ceejayt
    Aug 12, 2015
    403
    514
    York
    That's what I figured, thanks
  13. scotjimland
    Jul 25, 2007
    28,936
    25,589
    It 'should' be turned off at source, but in all my trips never had anyone actually check that it was..
  14. Cavs
    Cavs Funster
    Apr 10, 2010
    245
    245
    Bedfordshire
    That's interesting; I've had the gas bottles checked every single time I've travelled on the tunnel, which is well into double figures. I expect, if you explain, that turning off each individual appliance valve might be acceptable.
    As to the OP, as everyone else says, if you make sure you book as a camper van there is nowhere to put weight on the booking form.
  15. scotjimland
    Jul 25, 2007
    28,936
    25,589
    that's just my experience..
    last trip was Aug this year, just asked.. then told to go.. you must have a guilty looking face...
    • Like Like x 1
  16. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,562
    3,020
    East london
    Been checked about 50% of the time.
  17. frogijock
    frogijock Funster
    Jul 3, 2008
    705
    406
    Lincolnshire
    Only not had my gas checked once and that was because they were running late and had an overflow of vehicles, it was also a couple of day's before Christmas
  18. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,071
    1,250
    Fareham, Hants
    I have seen a you tube video about a beginners guide to the tunnel. He arrives at the check in and someone makes him wait until they have checked his gas is off. Poster says that this is the first time he has been checked at the check in point as he always has been directed to a large pull in area. There was a que where he pointed this area to be though so it certainly looks like they should check everyone. If getting to the tanks is awkward use the checker man to turn them off. - while your there mate!!!
    • Like Like x 1
  19. ceejayt
    Aug 12, 2015
    403
    514
    York
    So, I have always been asked and even had them come in the van to check the fridge is actually off and have said I have turned them all off and they have been happy. When we had a gas locker they always checked the cylinders but now the underslung tank has a protective cover which has to be undone and then turn off gas, replace cover and reverse at the other end. This involves getting under the van so have to admit, I have never bothered. The design has 4 separate taps located in a flap under the sink. Open the flat and turn each of four knobs (hob, oven, fridge and BBQ point) to off which I have done every time.
  20. madgeD
    madgeD Funster
    Aug 17, 2014
    255
    468
    Cleveland
    My advise is turn it off before you enter the area ie home or camp site , when they ask tell them its off but show them where it is, if they want to get underneath that is up to them ;) I don't think they will bother. But they have asked us every time , they dont always check.
Similar Threads
  1. Edenside
    8
    364
  2. t660
    7
    886
  3. EX51SSS
    22
    886
  4. sillybug
    330
  5. RGCH999
    63
    3,144
