Trying to identify this Electrical connection
Discussion in 'Motorhome Chat' started by namwaldog, Apr 20, 2016.
  1. namwaldog
    namwaldog Funster
    Jan 2, 2015
    438
    738
    Cumbria
    I want to move the switch for the Truma Ultrastore water heater. The switch, for some reason, is under the bed and I would like to move it to a more accessible position.
    There are a set of connectors on the cabling to the switch and I need to identify them in order to see how the cable should be attached to the connectors. I don't want to start taking them apart until I find out the correct method. One side of the connectors seems to have a heatshrink gland and the other has insulation tape.
    Anyone any ideas?
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,548
    5,633
    West Sussex
    Could be either a Molex or Amp automotive connector, there should be a part number moulded on it somewhere find it and Google it should turn up something, problem will be trying to buy in small quantity, if not on ebay.
    • Thanks Thanks x 1
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    Looks like a Molex Minifit
    • Thanks Thanks x 1
  4. Geordies
    Geordies Funster
    May 29, 2013
    944
    2,139
    Tyneside
    We used to buy similar plugs from Farnell.
    • Thanks Thanks x 1
  5. rickwiggans
    rickwiggans Funster
    Apr 2, 2014
    75
    56
    Lancashire
    CPC do these, usually available in ones.
    • Thanks Thanks x 1
  6. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    • Thanks Thanks x 1
    • Useful Useful x 1
  7. namwaldog
    namwaldog Funster
    Jan 2, 2015
    438
    738
    Cumbria
    Thanks for all the replies. The connectors are carrying mains power (240v) to the water heater and have been used to install an isolating switch under the bed. My idea was to extend the power in & power out cables from the connectors to the switch so that I could move the switch to a position where it was more accessible & visible.
    The more I have pondered over it, wondering if I should use heat resistant cabling (as in immersion heaters) and the possible effects of reverse polarity , together with the fact that the pattress box the switch is mounted on is quite bulky and not the neatest thing I've ever seen, I think I have decided to leave it as it is.
    Thanks again
  8. premiere99
    premiere99 Funster
    Aug 7, 2013
    72
    31
    Medomsley, County Durham
    • Like Like x 1
    • Thanks Thanks x 1
