Trumatic C problems in Marocco
Discussion in 'Tech/Mech General' started by Daiboy, Jan 18, 2014.
  1. Daiboy
    Daiboy Funster
    Sep 21, 2012
    64
    105
    Swansea
    Hi folks
    My Trumatic C boiler lights runs for about a minute and then trips (red light comes on on the switch panel). It does light you can feel the heat coming out of the exhaust and when you switch the heater off the circulation fan blows warm air for about 2 minutes. I've checked the 2 fuses on the electric mother board and checked the exhaust for blockages. The exhaust/system fan can be seen working and you can feel the airflow at the exhaust. Any ideas?
    Ps my batteries are fully charged they've not gone below 12.7v.
    Marjohn has fitted a Maroc gas bottle into his system using his existing regulator but seems to be having problems. He describes it has only being half a flame and then it goes out. Any ideas?
    Thanks folks.
    Daiboy.
  2. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,690
    3,212
    East london
    Ours had a similar problem and it was the combustion fan..
  3. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,213
    3,575
    Lincolnshire
    Perhaps you need to feed the Maroc Gas through a Maroc regulator - assuming you are feeding through two regulators
    Is your battery voltage up to scratch and not the cause of the flame failure?
  4. Daiboy
    Daiboy Funster
    Sep 21, 2012
    64
    105
    Swansea
    Thanks Sdc, I've had a look and you can see the fan running but maybe it not running fast enough.
    Dai
  5. Daiboy
    Daiboy Funster
    Sep 21, 2012
    64
    105
    Swansea
    Thanks Ken, I'm going over to look at Johns once I've sorted ( or given up on) my heating.
    Dai
  6. Allanm
    Allanm Funster
    Jun 30, 2013
    3,186
    4,342
    Cotes d'armor, France
    I'm sure you've tried it, but I have had a similar problem a couple of times and resetting the whole system cured it for me. I switched off the heater, switched off the power at the control panel then turned the master switch off. Then all back on again. Had to reset the clocks but it worked ok for me.
    Allan
    • Like it Like it x 1
