Trumatic C 6002 problem (1 Viewer)
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
Hi, run out of gas so red light comes on and heating stops. Next day fill back up with gas. Cooker is working, fridge is working gas at heater but red light will not go out so will not run. I have disconnected power reconnnected, fan will run and it will work on mains but not gas.
Any ideas please.
Steve
Nov 25, 2013
1,114
1,753
kent
Swift Kontiki 669
Since April 2013
Red light means a fault, not only lack of gas.
Martin
Steve
Steve
1,613
2,062
Compton Berkshire
C class
Yes but untill i ran out of gas there was no fault. In the past when i run out the light comes on, when i refill turn the heater off for a few mins. then back on as per the book it resets and all is ok but this time it wont reset why?????
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
Have you checked for a tripped switch?
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Any ideas please.
Steve
Just had exactly the same! It was the regulator! Changed that all now ok! Regulator was not supplying enough gas for heating boiler. It would fire up then trip the Truma regulator
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Hi, i've checked web best i can at minute. Apparently theres a reset button on the boiler on some 6002.
Have a look through this link for same fault theres a couple of tips...
Broken Link Removed
Steve
Steve
1,613
2,062
Compton Berkshire
C class
I am thinking along the same lines myself, not enough pressure to open the solinoid valve but ok for the cooker and fridge as they are free flow. Its the origininal one anyway so ten years old. i will replace asap. If anyother ideas please keep them coming.
Steve
Feb 26, 2012
528
368
coach
Just been looking for similar faults on other forums.
Have a look at this one Broken Link Removed
Whether the red reset button is for everything or just for the electric element I can't advise but it's worth a check if it is easily accessible.
Feb 26, 2012
528
368
coach
Sorry, that link does't work.
Feb 26, 2012
528
368
coach
Try www.motorhomefacts.com
then look for Truma c 6002 eh red light ... in the alps! the comment about the reset button is at the bottom of the thread.
Feb 26, 2012
528
368
coach
I tried to copy the web address for www.motorhomefacts but it comes up with The Dark Side
Steve
Steve
1,613
2,062
Compton Berkshire
C class
hi,
the reset button is for the 230v side, if it over heats it will trip. My problem is with the gas side as the unit is only a year old i am hoping that there are no internal problems! untill the gas supply is checked i could be jumping to all sort on conclusions. So tomorrow i will fit a new regulator, i carry one just in case! but as it is 'still working' ie some gas is coming out but maybe not enough. I will change it to eliminate the posssible vault then see if it the heater will play if not back to the drawing board.
Feb 26, 2012
528
368
coach
Ok. but it seems a bit of a coincidence if the regulator failed at that point.
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
If you look at the front of the boiler there is a large rectangular cover over the pcb.. Disconnect the power wires from the left of it and remove it. There are two slow burn fuses there.. Glass ones that need to be checked. The reset switch for the boiler is at 2 o clock roughly from that pcb.. Round the other side of the boiler. You slide the small cover off the button and press it.
Steve
Steve
1,613
2,062
Compton Berkshire
C class
well fitted new regulator but still not working.
checked fuses, checked trip, check power, check gas, red light is on not flashing, i can hear no cleaks from the solinodes nothing. all else working on mains.
so is the next step an engineer?
Steve
Feb 26, 2012
528
368
coach
Sorry to here that. Do you have an engineer in your area?
Steve
Steve
1,613
2,062
Compton Berkshire
C class
i will have a look tomorrow, i live a few miles north of newbury if anyone has a contact in this area please let me know. i am thinking that it might be the pcb so if it is may try talking to supplier as not that old
Steve
greygit
273
225
Forest of Dean, Glos, France and Spain
We had a similar problem here in Spain with our Gaslow system, as it was so cold here there was not enough Propane in the GPL locally and although gas hobs/oven working fine the heating wouldn’t work. As soon as I coupled up a Propane bottle to the Galsow filler connection, all was fine.
Steve
Steve
1,613
2,062
Compton Berkshire
C class
I have taken the unit out and asked the service guys at the workshop to have a look at it but was alarmed to see the mark it has made on the floor! looks like it has got a bit hot.
Steve
Steve
1,613
2,062
Compton Berkshire
C class
update.
I spoke to the service dept. and they said that the pcb was dead and would need replacing and were still trying to find the course. As the unit is only 8 months old and has 24 months warrenty i am hoping that it will cost me very little apart from having to take it out and refit it.
The down side is all this is going to take time could be a couple of weeks. Looking back i replaced the two units with this one, seperate water and heat and now have none so maybe look at going back to seperate units so if one fails i still have the other. Views please.
Steve
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I guess this is a new OLD STOCK? as the 6002 has been obsolete for years. Is it from Magnums?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Have you spoken to him?
I have the 6002EH in storage from there for future
Steve
Steve
1,613
2,062
Compton Berkshire
C class
Yes they were ok about it, they said take it to a truma agent which i did. and yes it is a 6002eh.
was working fine... then it wasnt. thought it may have been gas problem but would seem to be electrical...may never know.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Does the red light come on as soon as you apply 12 volts or after attempting to fire up?
OR does the fan start to run slowly and then the red light?
Steve
Steve
1,613
2,062
Compton Berkshire
C class
The red light was on as soon as it was turned on, on not flashing and the fan would run at low speed. They have said that the pcb has at fault so i would think that they may have some test equipment. But may never know what has gone wrong. Down to Truma to replace parts etc (i hope) the feed back i have had is that they are good with warrenty work, we will see.
Steve
Steve
1,613
2,062
Compton Berkshire
C class
Well got the unit back today and refitted all working ok. They could find nothing wrong after removing and refitting the pcb, but a know problem are board connections and removing and refitting has been known to fix the problem. So all well for now but i have fitted a protex 2000e heater and a propex malaga 5e water heater as back-up and or quick warm up if ever required. So even though the truma was foc. the other bits cost a bit.
Steve
