Truma won't stop sparking
Discussion in 'Heating and Air-Conditioning' started by bobbybear, Nov 16, 2012.
  1. bobbybear
    bobbybear Read Only Funster
    Nov 14, 2012
    5
    Kent
    The Truma heater in my 2001 CI Riviera carries on sparking after the heater is lit , I am happy with removing and replacing the burner and micro switch , i see the switch is availiable seperately, is that the likely suspect? .the ignitor box produces strong regular sparks when tested on the bench but the spark is weaker and less regular when installed so i suspect that the earthing is poor, i suspect the high voltage earths in the micro switch and back to the ignitor box through the two low voltage leads, there is no where else for it to go.HAs anyone stripped and re-assembled a mico switch?.
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    It will be the ignitor box, which I suspect is automatic one. They are prone to failure, usually caused by either damp causing arcing or a dry joint. They are usually sealed. Though older ones are servicable.
  3. bobbybear
    Nov 14, 2012
    5
    Kent
    Hi, thats what i fisrt thought but the unit sparks strongly and reliably off the van but reinstalling it makes things intermittent and weak,this points to a problem somewhere else, however the carrying on sparking may well be the box ,how does the switching off come about??.
  4. rainbow chasers
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    In simple terms it works by a thermo switch inside the ignitor box switching off when the thermo couple heats up, telling the ignitor that a flame is present.
    The oil gunge that forms in the pipes will eventually dry out and form a 'grit' - this usually is the culprit for blocking gas jets, regulators and the like. It can be duisolved and blown out usuing and air duster can and some hot water in most cases unless very bad.
    Your flame should be blue, if yellow or orange, there is dirt still present impedeing flow - you need around 30mb.
    • Like it Like it x 1
  5. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    truma
    Why don't you call out an engineer? If its the ignitor thats faulty then its an easy fix, if not it could be much more complex.
  6. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,343
    3,783
    walthamstow east london
    check everything is earthed properly not familiar with these but im aa gas eng on ng micro currrent passes through the flame to earth on the burners normally check leads connections and earth tags etc also the gap on electrodes unlikley to be the spark gen as thats working its just not getting the signal to stop reversed polarity can cause this but assuming it worked before and no electrics have been changed
