Truma Water heater
Discussion in 'Tech/Mech General' started by MaureenD, May 31, 2009.
  1. MaureenD
    MaureenD Read Only Funster
    Jan 15, 2008
    193
    11
    South Wales Vallys
    Can any one help.
    We have a Burstner performance 700 with 2 fixed single beds.
    When we use the water heater on gas we get a very strong Heat smell so strong we have to open vents. It's not a dust burning smell. also the mattress gets really red hot and you can't put your hand on the heater its too hot. I phoned Chelstons and they said its normal when using gas. Every thing is normal when we are on electric.
    Any one else got this problem or offer any advice please
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    im not trying to worry you but to my mind it should never get that hot!!!!
    worth having it checked by a competent corgi / gassafe registered service center.
    the last thing you need is a fire or burst boiler.
  3. nomadic
    nomadic Funster
    Sep 27, 2007
    692
    187
    Shropshire based
    MaureenD
    You don't say how old your unit is, but there was a call back on the C6002 boiler, and ours was one that needed the modification, and it was cooler "on gas" after that!
    I suggest you talk to Trume sercice/aftercare first, and see what they say, which I'm sure will be along the lines of get it checked at one of their service agents, and if one is closer than a long journey to your supplier, if it is new and under warranty, it should not cost you a penny. If its not under warranty, then you save on fuel costs.
    Most important think is don't leave it.....get it checked.
    Good luck
    Nomadic
  4. MaureenD
    Jan 15, 2008
    193
    11
    South Wales Vallys
    It was 2 years old in March. We bought it last November but had a full year warranty with Chelstons.
    Maureen
  5. nomadic
    nomadic Funster
    Sep 27, 2007
    692
    187
    Shropshire based
    If it is 2 years old, then it is a later model boiler, ours is a C6002, so if it is a different model number, then I would check with Truma, if your supplier is an approved Truma trained agent.
    Your dealer warranty should cover your boiler, but don't be supprised if they try the "its out of warranty" line. You do need to talk to truma first. Does it incurr a long journey?
    Hope all goes well
    Nomadic
  6. Pammy
    Pammy Funster
    Aug 3, 2007
    901
    120
    Mansfield
    Hi Muareen
    If you get the run around from Truma or your dealer you may have to do what Pappa John suggests and locate a Gas Safe Registered Engineer.
    Go on to the Gas Safe Register Gas Safe Register - make sure your gas engineer is registered
    On the Right hand side, put in your post code and try and locate an Engineer with the following qualification: WATLP2
    This certification covers engineers to work on LPG Caravan Water Heaters
    Hope this helps
    Pammy
  7. MaureenD
    Jan 15, 2008
    193
    11
    South Wales Vallys
    Thanks Pammy thats most helpful
  8. MaureenD
    Jan 15, 2008
    193
    11
    South Wales Vallys
    Just to let you know we went back to Chelston Motorhomes they inspected and agreed about all we had said. They said it was a design fault and agreed to do something about it so it went back to their workshops last Friday they cut a hole in the side of the van and put a Truma fan assisted vent in also they insulated the underside of the bed slats with a foil insulation. So jobs done lets hope its OK when we try it out.
  9. pappajohn
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    very good maureen,
    but if they said it was a design fault then the boiler should have been changed not just extra cooling.:Doh:
