truma water heater c3400 (1 Viewer)
Jan 27, 2014
2,074
4,407
mid wales
carthago chic i51.
Hi we have a truma water heater in our new to us
Moterhome hymer b564 1996 which is not working we have no power to it no lights
on the control panel on the wall above checked fuses psb board all ok
when tanks filled immediately start emptying
unable to keep yellow switch down to stop water
cannot find electric feed also no power to extractor fan
and two lights untill engine started mains lead working okplugged in
this is on rhs of van electric step and fridge ok
also all on rhs if anyone can understand my garbled message any advice please
we have warrenty but think some of the problems are our mistake thank you
TheBig1
17,628
43,233
sounds more like a blown fuse or loose wire in the supply cable. trace the wire back from the controller and see if there is one fitted inline if none on the distribution panel have failed. check them with a meter rather than just look at them
Beacons
Jan 27, 2014
2,074
4,407
mid wales
carthago chic i51.
Hi we checked all fuses with meter thanks kindly f or
your imput jan.
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Hi, don't know if this is any good, but maybe it has dumped all its water because of freezing as automatically dumps when it reaches 2 degrees just above freezing so as not to damage tank by freezing contents, can you pull up the yellow knob and if it still goes back down again put a clothes peg under it to stop it going down again, maybe this cuts off all electrics to stop it working when empty???????????????? just a thought, Regards Garry Flatpackchicken
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
My Truma is a different model but the automatic dump valve opens at 8c which is not even very cold, so at this time of year it may well open.
Beacons
Jan 27, 2014
2,074
4,407
mid wales
carthago chic i51.
Hi gary mike says
thank you for that brilliant piece of information
yes water is very cold from a well.
flatpackchicken
1,277
1,757
Since nov 2009
Hi, Hope you get it fixed soon and when you do don't forget to post on here what the problem was and what was done to fix it ok, as we all want to know as could happen to any of us, Regards Garry Flatpackchicken
