Truma water heater again (1 Viewer)
movan
21,492
120,753
Moving around
Burstner
since07
Staying at parents' and can't get home to the manual..
Whilst away at Ksbruce's birthday bash this weekend, my water heater would only work on the gas connection despite being on hook up. I suspect it must be a fuse which I havn't a clue where to look and how to check on this so that is a starter for ten please.... but my next question is what else should I look at to see if it working, if it turns out not to be a fuse? I DID have the water pump switched on (first time used it I didn't and wondered why it didn't work..:Blush:). Any help would be very much appreciated. (Also, would the fact that it was so cold have any effect on this?) Thank you in advance.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thanks for the pm and emails in response. Much appreciated.
However, Graham, has posted the following also, does anybody with an Eldiss know the answer please. Thank you.
According to my manual there is a fuse "on the electronic control unit on the water heater" but I don't know where, exactly, that would be.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
there are a number of people with this problem and I suspect it being a switch setting problem rather than a fuse, you can't have all blown the fuse.
GJH
29,450
38,827
None, now sold
2006 to 2022
Our Autoquest is a different model of van from Joy's but the electric switch for the water heater is a simple on/off one so not a lot to go wrong there.
The wiring diagrams I have indicate that the water heater is on the same circuit as at least some of the sockets but there is a fuse in the wiring between the "last" socket and the water heater.
My first reaction was that an overload might have tripped the circuit breaker protecting that circuit but Joys tells me only the water heater is not working, which would point to a fuse or the heater itself.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Back of the water heater, there should be a flap that swings away. Beneath that, there is a reset button. Try that first!
Just below it, there is a black control box - just have a look around and make sure it is ok, and not melted in any way - they have a fault on these - usually to do with gas though.
There will be an inline fuse, just off the heater, and one in the power control panel.
Terry
11,929
9,044
Lincolnshire
Can't remember ;)
Hi Joy, as you look at the heater you will see a triangular looking cover held in position by 1 /2 Phillips screws- undo this and lift top off, then pull up on side cover:thumb: this will expose the circuit board with a small fuse on it :thumb: You can also unclip the wires and remove the board for easy access to the fuse but be careful to clip it back in place correctly when refitting it :thumb:
terry
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thank you all. I will see what I can do.
It would help if it were easy to access .... I have to hang down the hole in the wardrobe floor and can't move about or see much down there!!!!!!
Will go and look for the flap at the back of the heater and the black box. and then the obscure fuse.
Joy x
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Joy x
We have a better idea Joy.
Rally the others up that could not get out for the snow and lets all go towards Morecambe and suprise Ksebruce and I will sort your heater out whilst we are there:thumb::thumb::thumb:
Alan and Lynda
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Alan and Lynda
YESSSSSS Please :thumb:
movan
movan
21,492
120,753
Moving around
Burstner
since07
:ROFLMAO:Oooops . sorry Alan. When are you thinking of going to Morecambe then? I might be able to go for the day. Will Skype you. :Smile:
Scout
3,958
120,964
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
I dont wish to state the obvious but please do not unscrew any electric cover with the power on........wait for somebody who knows what doing.
better to have no hot water than risk electric shock
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Joy
I had a similar prob, The fuse I found to out of place (I say out of place as it was not blown but taking out and replacing got it working ) on the side at the top there is a removable cover flat on top and rear side, a bit awkward to pull off but it will do, If the board you reveal is lit up red that's the prob it should be green, fuse is removable from there to check, Hope this helps Pete :thumb::thumb:
Benni-Boy
47
Halifax
30 years
Hi, I had the same problem before christmas. Would only work on gas and not electric. Turned out to be the immersion heater. Fortunately the mobile caravan repair man had one in his van. Cost £50 for replacement and fitting.:thumb:
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thanks Benni. Will bear that in mind when I try and sort it this weekend. :Smile:
