Truma Ultrastore Rapid (1 Viewer)
poppys
165
40
Norfolk
Since 1974 on and off
My Eldiss has one of these boilers fitted in the base of the wardrobe, with the vent out of the side. When I run the taps Ive noticed that there is water dripping out of the vent .Ive checked for leaks and cannot find anything,and everything seems to be working O K.
Can anyone throw any light on this. Chris
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Sounds like expansion leakage. This is usually dealt with by an expansion vessel, or an air bubble in the tank. I know nothing about the Truma heater specifically, but there is a good likelihood that it has either a broken expansion vessel or its air bubble has dissolved away and needs reestablishing.
P
poppys
165
40
Norfolk
Thought it may be something like that,typical just before we are due to go away,will have to live with it for now then.
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
BEEN BUILDING THEM FOR 32 years
The outlet on the outside at the bottom of the vent is only there to allow any condensation to escape, if it is more than a few drips then I would say that the boiler tank has a leak, mine was around the top edge where it rests on the casing, but I have also known of it happening around the top (hot) outlet this happened to one of mine and believe me it was near impossible to spot only the water marks gave it away it was only like a pin prick but enough to leak when heated up. unfortunately to even get to the tank the whole unit needs to be removed and totally stripped out. The only other place I can think of where you might have a leak is where the 240v element is fixed into the side of the boiler this is reasonably easy to get at and worth checking first.
FULL TIMER
795
717
NORWICH
This might help you out a bit Link Removed
as you will see the tank and burner assembly are mounted within another steel casing which doesn't help when looking for leaks,
